Marc,
I've had a lot of luck with small PVC (plumbing) tubes. I have
several of different sizes (length and diameter). If you can pick a corner
and get it started, then use the tube to wrap it around. The tube applies
more even pressure across the skin and it's not so hard on your fingers.
Even my more difficult coverings come off easier with the tubes.
marc.van.hulzen@dcsol.com
Sent: Sunday, May 08, 2011 2:23 AM
Subject: [rebel-builders] protection foil
Hello,
I've just finished the roof plate but there are difficulties with the
removal of
the protection foil. The foil is on the sheet for almost 15 years now.
I have tried paint remover, a paint stripper and several chemicals without
result.
Any suggestions will be appreciated.
Marc
I used a heat gun with very good results.
Gordon
From: marc.van.hulzen@dcsol.com<mailto:marc.van.hulzen@dcsol.com>
To: rebel-builders@dcsol.com<mailto:rebel-builders@dcsol.com>
Sent: Sunday, May 08, 2011 1:22 AM
Hello,
I've just finished the roof plate but there are difficulties with the removal of
result.
Marc
List archives located at: https://mail.dcsol.com/login<https://ma ... .com/login>
Unsubscribe: rebel-builders-unsubscribe@dcsol.com<mailto:rebel-builders-unsubscribe@dcsol.com>
List administrator: mike.davis@dcsol.com<mailto:mike.davis@dcsol.com>
Gordon
Hello,
result.
Marc
Both lighter fluid and Goof Off have been recommended in the past.
Ron
Ron
Ya, I know what you mean. I tried allkinds of guck too then, because
I was working in a fairly cool shop I
warmed the sheet up with a heat lamp and was able to increase the peel rate
immensly.
Hope this helps, Bob Elite 710
immensly.
Thank you all for your respond.
I'm going to check if the plate can resist my patience....
Marc
-----Oorspronkelijk bericht-----
Van: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] Namens Bob Bjorn
Verzonden: maandag 9 mei 2011 17:27
Aan: rebel-builders@dcsol.com
Onderwerp: Re: [rebel-builders] protection foil
immensly.
Marc
immensly.
