[rebel-builders] shaking
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 8:50 pm
Perhaps the door under the wing is the problem, your disrupting the
clean air flow for over 2 bays ??
mike
karl hipp
Sent: May 4, 2011 10:55 AM
Subject: [rebel-builders] shaking
does anyone have a cure for flying with the door open and avoiding the
"shakes"?
I converted my Rebel to gull wing doors. I have a latch pin to hold the
door open against the bottom of the wing so the door remains in place.
I installed a solid plywood bulkhead at the second bulkhead point behind
the seats.
There is a constant shaking and bad yaw if I attempt to fly with the
door open.
I have not tried opening both doors. Usually the shaking is so bad that
I cannot convince the passenger that opening that door would be a good
thing. They are usually "asking" me to close my door.
Karl Hipp
karl hipp
Post by karl hipp » Sun Feb 19, 2012 8:50 pm
I tried with the door OFF--same result.
mike
karl hipp
"shakes"?
the seats.
door open.
Karl Hipp
Post by Bob Patterson » Sun Feb 19, 2012 8:50 pm
Hi Karl !
You are right - just open the other door !! :-)
There will still be some buffet, but at least it will be
balanced. ;-)
It's the same with opening windows - better with
both open. (NEVER better with WinDoze !! ;-) )
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
"shakes"?
the seats.
door open.
Karl Hipp
Jones, Michael
Perhaps something to stiffen all the panels in the fuselage, insulation,
make sure tail cone is not leaking air through it, etc
know others have flow with doors off so there must be answers out there,
maybe on the web site
cheers
karl hipp
Sent: May 4, 2011 11:16 AM
Subject: Re: [rebel-builders] shaking
mike
karl hipp
"shakes"?
behind
the seats.
door open.
that
Karl Hipp
Miller, Ross W
Post by Miller, Ross W » Sun Feb 19, 2012 8:50 pm
Have you tried it with both doors removed - no passenger?
Sent: Wednesday, May 04, 2011 11:15 AM
To: rebel-builders@dcsol.com <rebel-builders@dcsol.com>
mike
karl hipp
"shakes"?
the seats.
door open.
Karl Hipp
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 8:50 pm
Some of the "jumper" planes add a small deflector at the normal hinge point,
2 or 3" and mounted at about 30* - 45* to the fuselage.
Dick Wampach SR-108
Patterson
Sent: Wednesday, May 04, 2011 8:22 AM
Hi Karl !
balanced. ;-)
bobp@prosumers.ca
bobp@pattersys.com
"shakes"?
the door open against the bottom of the wing so the door remains in
place. I installed a solid plywood bulkhead at the second bulkhead
point behind the seats.
door open.
that I cannot convince the passenger that opening that door would be a
good thing. They are usually "asking" me to close my door.
Karl Hipp
password "builder"
Dick Wampach
Keep in mind if the passenger is complaining --- have him step out! Or
forever hold his silence...
Miller, Ross W
mike
karl hipp
"shakes"?
point behind
the seats.
door open.
Karl Hipp
password "builder"
password "builder"
karl hipp
not tried that
To: rebel-builders@dcsol.com<rebel-builders@dcsol.com>
mike
karl hipp
"shakes"?
the seats.
door open.
Karl Hipp
Miller, Ross W
I've found in "test flying" that you can concentrate on what the airplane/systems are doing when there isn't a "high frequency noise generator" in the other seat :) !
Sent: Wednesday, May 04, 2011 11:55 AM
not tried that
mike
karl hipp
"shakes"?
the seats.
door open.
Karl Hipp
