[rebel-builders] exhaust hangers
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:50 pm
Rick.. I've never used that exhaust, but you'd want to adjust them to where
you want them and then tighten them up. I'd think solid would be better than
any chance of them swinging against something you don't want melted/worn
thru.
The other style is a ball socket that you adjust to where you want it and
then drill for a stainless rivet to lock in place.
Did you get those floats slid back out into place on the spreaders??
Sent: Wednesday, April 27, 2011 2:01 PM
Subject: RE: [rebel-builders] Gord Mohr's Bushings - Bolt ?
Hello Wayne
It looks like I'm going to have to change my tail pipe hanger,oops didn t
see that pic till you pointed it out.Do you know the proper tension on the
bolts and springs for the ball joint.Should it be none moveable or
slightly moveable?
Good health to Jennifer,I'm sure all will work out well.
Rick
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 8:50 pm
Since we are talking about exhausts, I cant find a tool to get onto the
exhaust lugs to tighten them, socket and wrenches can do some but
difficult to get at some of the studs, any suggestions
cheers
Sent: April 27, 2011 3:17 PM
Subject: Re: [rebel-builders] exhaust hangers
where
than
thru.
Hello Wayne
didn t
slightly moveable?
Rick
Always one or two that aren't convenient to get at... I'm generally using a
thin walled deep socket and a 12 inch extension Mike.
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Wednesday, April 27, 2011 3:20 PM
Subject: RE: [rebel-builders] exhaust hangers
cheers
where
than
thru.
Hello Wayne
didn t
slightly moveable?
Rick
drewjan
Post by drewjan » Sun Feb 19, 2012 8:50 pm
I have a 1/4"drive socket that I ground down so that it fits and use it only on those tough to get at studs.
Sender: mike.davis@dcsol.com
Date: Wed, 27 Apr 2011 15:20:29
cheers
where
than
thru.
Hello Wayne
didn t
slightly moveable?
Rick
rick greenwood
Post by rick greenwood » Sun Feb 19, 2012 8:50 pm
Wayne,Ya thats the way I have it now, can't move it by hand but the springes are not fully compressed,I think it should work like that.
Not yet,I'm trying to finnish up the engine work(2or 3 weeks)then tackle the floats.I think I'll let some air out and put some wax on the tubes hopefully goes easyer than narrowing them.
Rick
Date: Wed, 27 Apr 2011 15:16:49 -0400
thru.
Hello Wayne
slightly moveable?
Rick
