[rebel-builders] Rudder Pedal Mounting
Posted: Sun Feb 19, 2012 11:43 pm
Does your delron blocks have an offset? What are your block measurements?
On 2011-04-11 5:21 PM, "Roland Kriening" <kriening@rogers.com> wrote:
downI am test fitting my rudder pedals. After installing the 5/8 X 5/8 tube
upthe center of the floor I am finding that the rudder pedal assembly rides
onon it and I cannot get both of the delrin bearing blocks to sit squarely
inch.the floor. If I push one side down the other side rises up almost 1/4
forceEven with the doubler under the block I will still have a space. If I
it down the rudder assembly will be really tight against the centre square
tube. Doesn't seem right. Is there something I am missing?
Roland
R56
