matter if it was with the O-235 on it.... O-320 or when on Amphibs as is
evident in all my videos I took last summer. I started mounting everyone
elses stabs at 0.7/0.8 degrees in 1996 and they seem to cruise darn close to
neutral elevator.
To change yours now... if you haven't made fairings... requires a new hole
for the anchor nuts.. probably a doubler plate to do so. Not a big deal. If
you've already made your fairings.. just carry on and fly what you have.
Sent: Thursday, April 07, 2011 6:14 PM
Subject: Re: [rebel-builders] reflex
Hi Jesse, Walter, every one
Before I heard Rebel builders were changing the angle of incidence on the
horizontal stab I set mine by the manual to 1 degree. I plan to certify at
1,320 gross, wheels only, my engine is a Lyc. O-235, 115 Hp. Should I be
changing my angle to something less?
Charlie 802R
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Thursday, April 07, 2011 2:25 PM
Subject: RE: [rebel-builders] reflex
Thanks for the input Ken,
I don't feel so bad now. I thought it may have had to do with my wing
tail
incidences but who knows. I set .5 degrees on the horizontal stab which
gives a neutral elevator in flight with an average load.
Date: Tue, 5 Apr 2011 13:45:33 -0400
Mine is the same Jesse. Might get a knot or two when I'm very very light
but that hardly ever is the case. Can't explain why it works better for
everyone else other than that I normally cruise quite slow and the pitch
(nose up) is noticeably higher when I reflex.
On 4/5/2011 11:10 AM, Jesse Jenks wrote:
