[rebel-builders] RE: flaperon drain grommets
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:42 pm
What kind of cement, Keith?
In and of itself, "a lot of extra work" has rarely, if ever, kept me from
doing something -- over and over. It could (should?) be time to turn over a
new leaf though. ;)
Ron
On Mon, Mar 7, 2011 at 9:33 PM, <kpierson@dcsol.com> wrote:
Ron: I have done a lot of fabric work over the years,and as a general rule
you install a grommet on the high side of each rib, at the juction of the
rib
and trailing edge ( this is an absolute when ribs are wood.) They should be
installed before the finish coat of pt. A trick I use to keep things a
little
cleaner, is to slip the grommet over a large flat screw driver, to make it
easier
to hold, while applying the bonding cement with a small brush then set it
over the hole with the screw driveer. I apply quite a bit of cement and
press
them firmly in place with my fingers. I have never installed a patch over
them and have never lost one, it seems like a lot of extra work to me.
Keith P. Tail draggers for ever.
drewjan
Post by drewjan » Sun Feb 19, 2012 8:42 pm
If you used stits process for your fabric then poly-tac would be the cement. At least that's what I used and my grommets are still stuck on.
Sender: mike.davis@dcsol.com
Date: Mon, 07 Mar 2011 22:35:44
Subject: Re: [rebel-builders] RE: flaperon drain grommets
new leaf though. ;)
Ron
rib
little
easier
press
kpierson
Post by kpierson » Sun Feb 19, 2012 8:42 pm
Ron: What I mean by cement is the glue that is used to bond the fabric
to the structure. Even model airplane glue will work in a pinch.
If you ever have to place one or two on an uneven surface it helps to
warm them a little. I have done this with a hair drier, or heat gun but
don't over heat them and melt them.
On 3/7/2011 9:35 PM, rshannon@cruzcom.com wrote to rebel-builders:
-> What kind of cement, Keith?
-> In and of itself, "a lot of extra work" has rarely, if ever, kept me from
-> doing something -- over and over. It could (should?) be time to turn over a
-> new leaf though. ;)
-> Ron
-> On Mon, Mar 7, 2011 at 9:33 PM, <kpierson@dcsol.com> wrote:
-> > Ron: I have done a lot of fabric work over the years,and as a general
rule
-> > you install a grommet on the high side of each rib, at the juction of the
-> > rib
-> > and trailing edge ( this is an absolute when ribs are wood.) They should
be
-> > installed before the finish coat of pt. A trick I use to keep things a
-> > little
-> > cleaner, is to slip the grommet over a large flat screw driver, to make it
-> > easier
-> > to hold, while applying the bonding cement with a small brush then set it
-> > over the hole with the screw driveer. I apply quite a bit of cement and
-> > press
-> > them firmly in place with my fingers. I have never installed a patch over
-> > them and have never lost one, it seems like a lot of extra work to me.
-> > Keith P. Tail draggers for ever.
