Propeller Requirement
Posted: Sun Feb 19, 2012 11:42 pm
Gentlemen,
As you may recall, I'm building an SR2500 (#093). I'm
trying to stick as much as possible to the original plans, but include the
modifications that were necessary for strengthening/safety and not those
that were specifically designed for the Moose. I've purchased a freshly
overhauled Lycoming O-540 A1A5 rebuilt to A4D5 specifications in order to
match up with the Murphy recommended Hartzell propeller, the
HC-C2YR-1BF/F8477 Propeller with the V-3-7 governor (for the narrow deck)
and A-2298-2P spinner. I've been searching all the propeller overhaul
folks throughout the US looking for a good used/reconditioned propeller.
I've located the same propeller, overhauled, but with F8477-2 blades, 2
inches shorter than the original. It would be an 82" diameter vs. 84"
diameter with everything else being equal. My question is how would that
affect the performance of the Super Rebel and what should I be considering?
The propeller is freshly overhauled and would have another 1-2 overhauls
remaining based on the blade specs.
www.mykitlog.com/jfolkerts/
