I can't help you with the vacume it takes to damage your tank.I built a
Monometer out of 3/8 PVC clear tube mounted on a large piece of plywood with
14.5 and 20" above and below 0". Stuck my shop vac hose in the tank and
sealed it with duck tape. I was able to pull about 18" and the tank walls
really sucked in. You can regulate it some what by how well you seal the
duck tape. If the tank gets to looking to bad pull the plug on the shop vac.
Will send photo off line. Good luck. Let me know if successfull I may have t
o do it again.
Charlie E. 802R
Sent: Tuesday, March 01, 2011 8:53 PM
Subject: [rebel-builders] Re: max tank vacuum
Golly, I was just kidding about the PS but, to show remorse & reform
anyway,
I've already (re)enrolled in the Rebel Builder's Etiquette & Ethics
Education Program (a.k.a. "RBEEEP"). ;-)
One person replied direct, conveying someone else's (anonymous)
quasi-formal
engineering analysis (with graphics I don't really understand) to the
effect
that a 1.5 PSI vacuum should not be feared. Has anyone actually had the
misfortune to crumple the tanks doing this?
Ron
On Tue, Mar 1, 2011 at 3:15 PM, Ron Shannon <rshannon@cruzcom.com> wrote:
So... I'm going after the fuel tank seepage again once again attempting
draw in Loctite 609 with negative tank pressure, as recommended by my EAA
Tech Advisor months ago. The seepage hasn't kept me from putting on 65+
hrs., but is a nuisance, and something I would like to correct before
painting, if possible. The first time I did this I used ~0.5 PSI of
vacuum,
as measured by a rather sticky, non-precision meter -- with not very
impressive results. This time I have fancier equipment, and am
contemplating
probably going to ~28 in/WC (1.01 PSI) or thereabouts. I know this issue
has
been loosely covered a few times before, but the question is:
What is the maximum recommended vacuum pressure, short of inviting an
implosion disaster? I need to calibrate the non-precision anxiety meter
max out at a slightly lower value.
Thanks.
Ron
PS - Along with your recommendation, please include your current home
address, driver's license, passport #, spouse's name, name and DOB of
first
born, etc.
