[rebel-builders] FUS 7 & Moving Firewall Back 3"
Posted: Sun Feb 19, 2012 11:41 pm
It is nice to see that everyone has their personal opinion on firewall
position......... that's what an open forum is for.
But some consideration should be given to the designer's insight on why the
firewall is positioned where it is and why....... take the time and read.
https://mail.dcsol.com/code/html-fdnld? ... cno=963072
The above link is in the files under R-206 Fuselage.
On Mon, Feb 28, 2011 at 6:04 PM, Jim Parr <jparr@accesscomm.ca> wrote:
Hi Jose,
all pictures are welcome! And thanks to all who responded.
you can send to me off list @ jparr@accesscomm.ca
Jim 705R
Sent: Monday, February 28, 2011 5:17 PM
Subject: Re: [rebel-builders] FUS 7
LotsHi,
I am in the middle of this job. I must say it has been an experience.theof work the manual doesnt tell you I found. I only have 1 more fuse 70 to
install. If you would like i can send you pics of what I've got so far.
Bob
Patterson said " oh no " when I told him I started in on it. He was right
but too late it is done. It will turn out ok but lots of frigging around
do it. If I had it to do over again I probably wouldn't have done it but
like i said, so far so good, 1 pc. to go. Just lots of extra time.
Jose
805R
Sent: Sunday, February 27, 2011 8:40 PM
Subject: [rebel-builders] FUS 7
We are at the point where we are putting FUS 7 and the firewall in totoRebel. We are putting in a Lycoming 0290 and the plans say cut the
flange
back on FUS 7 3 inches but the picture shows cutting FUS 7 all the way
across. If we do this won't the fuselage stick out on both sides? The
cross pipes FUS 5 will be too long then? What exactly are we supposeddo here?
Jim
705R
