[rebel-builders] FUS 7
Posted: Sun Feb 19, 2012 11:41 pm
by drewjan
Before you move your firewall back I suggest doing some research in the archives. There's lots of rebels flying with bigger engines and the firewall in the origional position.
Sender: mike.davis@dcsol.com
Date: Sun, 27 Feb 2011 20:40:30
Subject: [rebel-builders] FUS 7
We are at the point where we are putting FUS 7 and the firewall in to the Rebel. We are putting in a Lycoming 0290 and the plans say cut the flange back on FUS 7 3 inches but the picture shows cutting FUS 7 all the way across. If we do this won't the fuselage stick out on both sides? The cross pipes FUS 5 will be too long then? What exactly are we supposed to do here?
Jim
705R
by Angus McKenzie
I fly Rebels in both firewall (fore and aft) configurations and unequivocally prefer the unmolested variety!
For a bunch of reasons...
Subject: Re: [rebel-builders] FUS 7
Date: Mon, 28 Feb 2011 14:30:11 +0000
Jim
705R
by David Jackson
I've also heard that you can cut the firewall back only 1 inch instead of the full three. This will improve the W&B while still allowing room behind the panel and not requiring a firewall extension under the windshield.
by Walter Klatt
If you're going to go through the extra work of cutting it back, might as
well go all the way to 3 inches. The only drawback that I know of is the
pilot sits back 3 more inches under the wing and loses a bit more
visibility. The benefits are better weight and balance to better handle the
bigger engines. Have to remember, too, that when the firewall is moved back
3 inches all your other cabin arms go back 3 inches as well, including
pilot/pax and baggage. So the improvement is not just the engine arm.
The panel is also cut back 3 inches with less of an angle on the sides, so
ends up with the same room behind as without the firewall cut back.
I have my firewall cut back 3 inches, and able to keep my battery forward of
the firewall with a Lyc 360 engine with a heavy metal prop.
Also be sure to upgrade your corner wraps in the front fuselage, bottom to
.032 and top to .025.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
Jackson
Sent: Monday, February 28, 2011 10:16 AM
To: Rebel Builders
Subject: RE: [rebel-builders] FUS 7
by Jose & Terry
Hi,
I am in the middle of this job. I must say it has been an experience. Lots
of work the manual doesnt tell you I found. I only have 1 more fuse 70 to
install. If you would like i can send you pics of what I've got so far. Bob
Patterson said " oh no " when I told him I started in on it. He was right
but too late it is done. It will turn out ok but lots of frigging around to
do it. If I had it to do over again I probably wouldn't have done it but
like i said, so far so good, 1 pc. to go. Just lots of extra time.
Jose
805R
Sent: Sunday, February 27, 2011 8:40 PM
do here?
Jim
705R
by Jim Parr
Hi Jose,
all pictures are welcome! And thanks to all who responded.
you can send to me off list @ jparr@accesscomm.ca
Jim 705R
Sent: Monday, February 28, 2011 5:17 PM
Hi,
Bob
Jose
805R
flange
do here?
Jim
705R
