[rebel-builders] Question of Rebel Datum location/ Cof G ran
[rebel-builders] Question of Rebel Datum location/ Cof G range
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:35 pm
as an adendum to that.. with Spring Gear.. bolt flange for axle may be
slightly forward of the door post centerline due to the taper cut of the
leaf. I have a set in the shop I'm gonna verify that on tomorrow. Even if it
is I can't see it being forward of the leading edge of the wing.
I know for fact that Gary has the bungee style gear though.. and it is
definitely centered on the door post.
Sent: Saturday, February 12, 2011 9:44 PM
Subject: Re: [rebel-builders] Question of Rebel Datum location/ Cof G range
That's interesting Ron.. considering the cabin bottom below the door sill
is
to be level for weighing.. and the door post is perpendicular to the cabin
bottom.. and the axle should be on the center line of the door post.. and
the door post is behind (aft of) the wings leading edge.
Sent: Saturday, February 12, 2011 9:27 PM
range
On 254R, with spring gear and 8.00x6.00 Carlisle turf tires, the center
the axle was 0.5" forward of a plumb bob dropped from the leading edge.
Ron
N254MR
On Sat, Feb 12, 2011 at 4:03 PM, Wayne G. O'Shea
<oifa@irishfield.on.ca>wrote:
Gary.. the axle center line is not ahead of the leading edge! It is
indeed
AFT of the wing leading edge.
