[rebel-builders] Fw: Batteries for Murphy Moose- Ballast
A few of my heavy friends use 1 gal milk bottles filled with water in a
cases that hold 4 bottles. You can carry it along as ballast, use as
drinking water if you went down in the remote, it won't hurt you as bad as a
brick if it becomes a projectile in a mishap, and the cost of dumping it and
a refill is minimal to nothing.
Dick Wampach SR-108 N331RW
wayne.pederson@dcsol.com
Sent: Friday, January 21, 2011 9:48 AM
Subject: Re: [rebel-builders] Fw: Batteries for Murphy Moose
I like the sand bag idea because when I get to where I need to load up I can
just empty the sand out and bring my bags back to use over again, (I sure
would not want to leave the oil unless I could put money in my pocket in
exchange) :)
-> A couple of CASES of OIL would be appropriate, and more
-> useful ! ;-) :-)
-> Well secured against the aft wall ...
-> ......bobp
-> bobp@prosumers.ca
-> bobp@pattersys.com
-> http://www.Pattersys.com
-> http://www.amway.ca/BobPatterson
-> Any views expressed in this message are those of the individual
-> sender and do not necessarily reflect the views of any other entities
-> or persons. Any action taken as a result of the contents of this
-> email is totally the responsibility of the reader.
-> On January 21, 2011 09:42:54 am ted@vafm.org wrote:
-> > I agree w/ Wayne; two 12's rather than one 24.
-> > I STRONGLY suggest you put the battery(s) as far FORWARD as
-> > possible-
-do
-> > NOT put them back in/behind your baggage area! Yes, the Moose is
-> > nose-heavy when you're flying solo. But the purpose of the Moose
-> > is to have a plane you can load with all you want to take on trips.
-> > If you
have
-> > the battery in the back you are starting the load process behind
-> > the weight curve. I can send you a W&B spreadsheet that you can
-> > play
with to
-> > see the adverse effect having that battery weight back there has on
your
-> > ability to load other stuff on a trip.
-> > When flying solo, I just put a couple of big bricks (wrapped in
-> > blankets) back in the baggage area.
password "builder"
exchange) :)
-> useful ! ;-) :-)
-> ......bobp
-> > possible-
-do
-> > If you
have
-> > play
with to
your
password "builder"
