control cable turnbuckles
Jason Beall
Post by Jason Beall » Sun Feb 19, 2012 8:35 pm
Guys,
Quick questions:
1)Do you think it's worth having at least two turnbuckles in each control system run to give more flexibility in adjusting tension?
and...
2)Any tips/tricks on getting the cables tight prior to installing the last turnbuckle/nicropress sleave combination? There is not much 'throw' or 'adjustment' on the turnbuckles, so I am worried I won't be able to get things tight.
Thanks, -Jason
