[rebel-builders] Moose & Elite new elevator and new horizontal stabiliz
Posted: Sun Feb 19, 2012 8:34 pm
Yes. I erred in the # of parts. I'll post a corrected total per Elite and Moose in the morning. Thank you for your note.
Jason Beall <super_rebel131@yahoo.com> wrote:
Hi Ted,
Aren't there four of these on the Moose horizontal stab/elevator, two either side of the center hinge point...I seem to recall the center hinge is the elevator horn? My stab and elevator are in a storage facility!
Thanks, -Jason
--- On Thu, 1/13/11, Ted Waltman <ted@vafm.org> wrote:
Subject: [rebel-builders] Moose & Elite new elevator and new horizontal stabilizer hinge/brackets
Date: Thursday, January 13, 2011, 8:15 AM
Folks,
I just uploaded six pictures to Area 122-S/M After Market
Products.� These
pictures show a new design for both Moose and Elite
elevator/horizontal
stabilizer hinge brackets.� I sent out a previous
email on this subject back
in November.� If you can't view the pictures on the
list, send me a private
email (tedwaltman@gmail.com)
and I'll email you part pictures.
Thank you for your patience while I worked through getting
actual
pre-production prototypes built by a machine
shop.���The attached pictures
show multiple views of the final product.
As you know, the new design replaces existing
four-separate-pieces (total 4
individual parts per "pair" in other words).� The
original parts are each
individually 6061 T6 0.125" thick.� So ST-318 as
originally part of the kit
is composed of two parts sandwiched together.� Each
"ear" of EL-300 is
0.0125" (picture labeled "original.jpg").
The rest of the attached pictures show the new design--
0.250" 6061 T6 hinge
bracket pairs.� Each ear of EL-300 is now 0.250"
thick.� In my original
email, I mentioned perhaps making these hinge/bracket (H/B)
pairs out of
2024 T3, which is approximately 20% to 25% stronger.�
Upon further
reflection, I thought to myself, "Gee, we're bolting this
already much
stronger assembly to a spar that itself thinner 6061 T6--so
why make this
hinge/bracket pair out of so much stronger material that it
then makes the
spar itself the weak point?"� Hence, the new H/B
design will be made out of
6061 T6.
The bearing you see on the ST-318 is a MS27641 sealed
bearing.� Sealed to
prevent moisture/dirt contamination down the road.�
Radial load bearing is
1100 lbs and thrust load bearing is 900 lbs in this 1/4"
bearing size.� Once
again, the sealed aspect keeps things clean from the
elements, something
that is clearly needed back on the elevator/horizontal
stabilizer.� The
bearing is pressed in and sealed with red Loctite.
The four mount holes on each piece are in the same exact
position as on the
standard parts.� Hence these after-market H/B pieces
will bolt directly to
your existing spars.
There is 0.005" clearance on each side of EL-300 for ST-318
to fit in
between.� This is a tight fit!� We could (but are
not) open up the spacing
to allow for a AN960-416L (0.016") or AN960-416 (0.032")
washer.� Doing so
however would allow for a bit of slop in case you had a
spar just a tad bit
out of perfect true.� It would be, as you can well
imagine, be an absolute
bear to get those washers in place.� Our current plan
is therefore to leave
the clearance as-is--0.005" each side or 0.010"
total.� If you need to
realign anything, you will need to do so by perhaps reaming
out one or more
of the four spar-mount holes on each side.
You do not want any slop in this assembly.� Slop is
what causes starts and
accentuates hole elongation in EL-300 (which is what led me
to start this
whole endeavor!).� With this new design, which again
only has 0.005" on each
side between each ear of EL-300 and the side of ST-318, you
put the two
pieces together and tighten the bolt/nut fully
together--tightly together.
With the design we have here, the bearing has an outer
surface against which
you chinch up--tighten--the ears of the EL-300.�
(Note: If we were to allow
for the use of washers, you would have to insure you get
the washers in
place and again fully tighten the nut/bolt assembly
together.� In this
example, the washer would not be a rotating surface but
only a spacer.)
There must be no--zero--side to side play or you will, even
with this new
design, eventually--further down the road at least--end up
with hole
elongation in EL-300.
Because this new design does not have a rotating bolt, one
can use a
standard AN365 fiber nut and a standard AN4-10 bolt--there
is no need for a
AN310-4 castle nut, MS24665-132 cotter pin, AN960-516
washers and drilled
AN-4-10A bolts.
Assembly:� Due to the tight tolerance, I suggest you
first bolt the EL-300
and ST-318 assembly together with the 4 AN-3 spar mount
bolts on each side
only loosely installed.� Keeping the AN-3 bolts very
loose (nut only hand
tight) will give you a few thousands play which will make
the pairing of
EL-300/ST-318 much easier.� Fully tighten the
AN4/AN365 nut/bolt then, and
only then, tighten the AN-3 nut/bolts down on the
respective spars.
There are 5 pairs of H/B on the Moose Elevator/H-stab and 3
pairs of H/B on
the Moose fin/rudder.� I believe the Elite would
require 4 EL-300 on the
rudder, 4 EL-300 on the Elevator, 3 ST-318 on the
horizontal stabilizer and
3 ST-318 on the vertical fin (someone please check my #'s
on the Elite).
I strongly encourage Moose folks to at least replace each
outer-most pair on
the elevator/h-stab.
Availability:� First week in February for initial
production run.
Pricing:
Those who firmly commit to and pay for an order prior to
Feb 1st: $75 per pair EL-300/ST-318 (plus shipping/handling
of $10 U.S.;
Canada $15)
After Feb 1st the price goes up to $90 a pair (plus
shipping/handling of $10 U.S.; Canada $15)
Shipping/handling charge is for total order--not for each
pair.
I'll provide a PayPal account for remittances.
Please email of course with any questions.� Again,
thank you for your
interest.
Ted Waltman
303-378-4987
