[rebel-builders] Preventing Moose/SR stinger side-to-side mo
Eduardo Gutierrez Sosa
[rebel-builders] Preventing Moose/SR stinger side-to-side movement
Post by Eduardo Gutierrez Sosa » Sun Feb 19, 2012 8:34 pm
Jason: I would not use anything but a good steel bushing machined to size;
rubber, delrin, or anything else which is "soft" will NOT last very long and
you may end up wondering around the landing field. That's my opinion,
regards to you all, a very Happy New Year to all, Eduardo
-----Mensaje original-----
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de Jason
Beall
Enviado el: jueves, 30 de diciembre de 2010 01:21 p.m.
Para: new list server
Asunto: [rebel-builders] Preventing Moose/SR stinger side-to-side movement
Guys,
Quick question: I have a custom stinger purchased from another builder a few
years back. It's 1 inch in diameter, so there is a slight gap either side of
the stinger up in the tailcone where it mounts.
What have others done to take up this gap? I was thinking either delrin
spacers or some sort of rubber cushion. Thoughts and/or suggestions?
I can see if you don't prevent the side-to-side movement it will eventually
wear the bolt hole on the stinger.
Thanks, -Jason
__________ Informaci
