[rebel-builders] Which Propeller for the SR2500
Posted: Sun Feb 19, 2012 11:07 pm
Jerry,
I fly an SR-2500 with a continental O-470-S with a McCauley S-90AT-8 on a C-50 hub. This is replaced by a C203 hub. I get a 136 mph cruise at 23^2.
This gives you an idea of performance, but you want to ensure you go with a tested propeller, engine combination (i.e. look at all the propellers that go with a O-540 engine on certified airplanes). Personally, I would not use an untested engine/propeller combination as you are running an experiment without the use of a test stand and reams of test equipment and a healthy engineering budget. There can be detrimental vibration issues with untested combos.
Tom Tonner
Tom Tonner
Subject: [rebel-builders] Which Propeller for the SR2500
Date: Tue, 7 Dec 2010 17:20:58 -0600
I've just started work on my SR2500. It will be powered by a Bob Barrows
built O-540, normally aspirated. With a goal of economical cruise, which
model Hartzell 2-bladed prop should I be looking for? Or, does anyone have
any experience with a MacCauley Brown? Or other propeller manufacturers?
