[rebel-builders] horizontal stab install for wheels only?
Posted: Sun Feb 19, 2012 8:07 pm
Sent: Sunday, December 05, 2010 12:17 PM
Subject: Re: [rebel-builders] horizontal stab install
Wayne:
I am looking as saving your tip below for future use, but then I got to
wondering if there is a noticeable difference between an aircraft on floats,
and one on wheels. If an aircraft is to be used on wheels only, would you
still use the 0.7 or 0.8 setting?
Tim Hickey
Rebel 808
Montrose, Iowa.
319 795 2684
On 12/5/2010 8:05 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Also keep in mind, if you haven't seen the posts, I have found over the
-> years that a stab incidence of 0.7 to 0.8 degrees is what is needed vs
-> 1.0 spelled out in the manual. At 1.0 you'll be flying with a hint of up
-> elevator all the time. You can see same in all my float flying videos.
-> Elevator tip is always down slightly compared to the stab leading edge on
-> mine, that is mounted at 1.0 All the ones I've built since have 0.7 or
0.8
-> and they seem to fly with the tip pretty much flush in cruise.
-> Wayne
Wayne:
Tim Hickey
Rebel 808
Montrose, Iowa.
319 795 2684
0.8
-> Wayne
