[rebel-builders] axle nuts...how tight?
Posted: Sun Feb 19, 2012 11:06 pm
Firmly tightened by fingers should be fine. You want no free play as
free play kills tapered roller bearings. Yes they may have noticeable
drag when turning by hand but that is expected. A little overtight is
better than under tight, same as for car axle bearings.
My 4 door cowl is all 0.020 and it has been problem free but all the
hinge and fastener edges are doubled or reinforced with angle. If you
don't have access to rollers I believe MAM suggests wrapping the doors
around a cylinder to get some curve in them.
Jesse Jenks wrote:
Jesse Jenks wrote:
I have the JDM wheels (newest available from MAM I believe). How
tight should I get the axle nuts? With the tires off the ground I can
tighten them enough by hand to slow down wheel rotation. I wouldn't
think I need to go any more than that, but not sure. Thanks Jesse
