Happy Halloween to you too and all on the list.
Nig
745E
_____
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Nancy
Puff
Sent: 23 October 2010 16:20
Subject: Re: [rebel-builders] Moose tailwheel
Happy Halloween everyone
Nancy
Sent: Saturday, October 23, 2010 8:15 AM
<http://www.akbushwheel.com/index.php?op ... =rokquickcEduardo,
I also recommend that you order directly from AK Bushwheel.
A couple of key points that you need to know:
- If you have the solid Murphy stinger, it is 1 1/16" which is of course
1/16" larger diameter than the hollow, original Murphy stinger
- The 2-bolt attach pattern on both the original Murphy hollow round
stinger
and the newer solid stock round stinger are spaced 1 3/16"
center-to-center. The bolt pattern on the AK Bushwheel (and Scott and
every
other assembly by all other manufacturers) is spaced at 1 1/4"
center-to-center.
On Sat, Oct 23, 2010 at 8:49 AM, Wayne G. O'Shea
<oifa@irishfield.on.ca>wrote:
Eduardo.. I would cancel your order with Spruce and buy it and the
required
spacer DIRECTLY from Alaskan Bushwheel. The way you'll get proper
customer
service if you have any issues with it, or have any questions when
ordering.
There are no better people in the aircraft parts world than Bill and Wup
at
ABW.
http://www.akbushwheel.com/index.php?op ... kquickcart
art&Itemid=58> &view=rokquickcart&Itemid=58
onlyWayne
From: "Eduardo Gutierrez Sosa" <lopeco.eduardo@gmail.com>
Sent: Saturday, October 23, 2010 10:41 AM
Subject: RE: [rebel-builders] Moose tailwheel
Hi Drew: I ordered the Alaskan Bushwheel Tailwheel, the one with the
10"
wheel, p/n 06-01149 from Aircraft Spruce,
http://www.aircraftspruce.com/catalog/l ... lwheel.php My
doubt is whether the one inch "head spacer" p/n 06-01158 is suitable
install in the Murphy tail spring which is a solid 1" round steel stock
(works very well), considering the tailwheel head is made to hold a
flat
spring steel. I'm sort of confused with this issue, and if anyone could
give
me ideas who to look for advise, this would be great.
Bolivia, Brazil and Argentina have a wide array of landscape; there
