Rudder Cable Fairing form
Posted: Sun Feb 19, 2012 11:05 pm
To: <schaumr@dcsol.com>
Sent: Tuesday, October 05, 2010 7:10 AM
Subject: Re: Rudder Cable Fairing form
Rob
The dimensions of the blocks were 4" x 5". The bottom was 1-1/2" thick
with a tappered pocket milled in it, the top was 3/4" MDF with a !/2" wide
x 3-1/4" lg slot to guide a 1/2" dia. tube. The form block was clamped
together in a vice and the 1/2" pipe was forced against the alum with a
large drift pin and a hammer untill seated to the tappered slot. The parts
are trimmed to size and require additional hand forming to fit the
fuselage. The whole process is very simple (some what crude actually) The
wood form blocks have a very short life (3 or 4 sets) untill it looses
defination. If I were to do it again I think I would check out the ones
ACS has in their catalog.
Charlie
To: <charlie@troyairpark.com>
Sent: Monday, October 04, 2010 12:35 PM
Subject: Rudder Cable Fairing form
Hi Charlie,
Ron Shannon shared some pictures of your rudder cable fairing form block,
which obviously produces terrific results! I was trying to duplicate it,
but my
first attempt (using 2 x 4 stock and a 7/8" pipe) cracked the wood
longitudinally when used with some 0.020" sheet. Are you able to share
dimentions (and materials) of the form block(s) and also let me know
whether
or not you hammer the pieces together, or compress in a vise? The top
block
looks like it's MDF....is that correct?
Any advice you've gleaned from the experience would be much appreciated.
Thanks so much,
Rob
Rebel786
