[rebel-builders] ST 31 Channel across firewall
Post by Bob Patterson » Sun Feb 19, 2012 8:05 pm
Hi Roland !
I would install the ST-31 -- part on front, part on back,
as recommended .....
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
On September 30, 2010 07:33:40 pm Roland Kriening wrote:
I am installing the doublers on the firewall as per Wayne's bullet proof
firewall. I noticed in looking at Roger Hoffman's pics that he did not
install the ST31 channel across the front of the firewall. Does the
installation of the doublers remove the need for the channel?
Roland
R56
snowyrvr
Post by snowyrvr » Sun Feb 19, 2012 8:05 pm
I asked Roger about this and he told me he didn't install the top cross channel because the eng mount he used incorporated that into it's design. CW
--- bobp@prosumers.ca wrote:
Subject: Re: [rebel-builders] ST 31 Channel across firewall
Date: Thu, 30 Sep 2010 20:27:25 -0400
Hi Roland !
bobp@prosumers.ca
bobp@pattersys.com
Roland
R56
That could be Craig - remember that he used a custom
engine mount for his IO-240 Continental, not a factory mount,
and may have been able to incorporate a cross tube between
the top 2 engine mounts with that setup ....
For standard engines, I would still add the channel - it's
not a lot of weight, to avoid a damaged firewall later ...
bobp@prosumers.ca
bobp@pattersys.com
CW
Hi Roland !
Roland
R56
