shaped clips used to fasten floor channels to each other or bulkheads, are
not necessary in the aft section. Leaving them out could save quite a bit of
time. Check the archives for this if interested.
-Ben
On 9/15/2010 7:54 PM, snowyrvr@mtaonline.net wrote to rebel-builders:
TheHi Marc,
Even though the manual says you can leave it out, I would not do that.
youpiece that comes with the kit is .020 and probably adds little more than a
few ounces, maybe a pound when you consider the rivets. For that weight
anyoneget some major stiffening/strengthening of that tail cone area. Plus, when
you have to get back there for something-and you will, you run the risk of
bending bulkheads or something else. My two cents. Craig
Sent: Wednesday, September 15, 2010 9:15 AM
Subject: [rebel-builders] Fw: bagage compartment part of the airframe
stiffness?
From: "Marc Van Hulzen" <marc.van.hulzen@dcsol.com>
To: <mike.davis@dcsol.com>
Sent: Wednesday, September 15, 2010 9:10 AM
Subject: bagage compartment part of the airframe stiffness?
I'd like to leave the bagage compartment out of the tailcone because of
weight saving. According the manual it seems it no problem but has
experience with it?
Any recommendations are appreciated.
Kind regards,
Marc van Hulzen
PH-REB
