[rebel-builders] wing repair
Billy Corbett
Post by Billy Corbett » Sun Feb 19, 2012 11:05 pm
Thanks a bunch!! This wing has the reinforcements and I have to say it looks hell for stout. Spar was drilled for strut fitting 2
inches too far inboard. The plan is to beef up the area to make up for the extra holes. Doublers with solid rivets as per 43.13 and
Cessna spar splice repair. Your are right about it being scary-the plan is to go overkill and take the weight penalty. Thanks again
Bill Corbett ----- Original Message -----
Sent: Tuesday, September 14, 2010 7:40 AM
Subject: [rebel-builders] wing repair
I'm hesitant to answer such a scary question. Hopefully you will measure
and confirm with certainty the thickness of what needs to be repaired.
You may be able to read markings on the material.
However my wing skins are 0.020 6061T6
Spar was 0.062 same material.
That was for a 1650 lb on wheels Rebel which has top and bottom bolted
on 1/4 x 1" spar reinforcements in the strut attach area as detailed in
the manual (or in the upgrade documentation if you have a very old
manual for the 1500 lb airframe). Please make sure you have those
reinforcements unless it is operating as an ultralight. I don't know
what material the 1/4 x 1" straps are.
Bolted on fittings are the stronger 2024T3 I believe.
mikeh@dcsol.com wrote:
On 9/13/2010 4:27 PM, spotter37@cox.net wrote to rebel-builders:
-> Help !! I need to identify the alloy, temper, and thickness of the Rebel
main spar. Looked through the builder's manual and the only
-> reference was by part #(W-112) E-mailed the Murphy site and called them
, no response. Need same info on wing skins. I am trying to
-> make a repair in the area of the strut attach fitting and need to order
material to make a sandwich type doubler as described in
-> 43.13 and Cessna's service manual. Thanks for any and all help with
this. Bill Corbett Spotter37@cox.net
