[rebel-builders] Pitot Angle
Posted: Sun Feb 19, 2012 9:32 pm
Well, it should be parallel to the airflow, so point it down maybe 3 degrees
relative to the under surface of the wing.
Al
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Thomas
Breitbach
Sent: Sunday, September 05, 2010 3:45 AM
Subject: [rebel-builders] Pitot Angle
Hello,
I am going to install the Murphy pitot tube (including static port). It
will be installed at the leading edge on the left wing.
As already suggested on this list a position in the fifth bay seems
best, since a can access the connections via the inspection holes of the
stab.
I am actually considering what angle is the best for the tube. My plan
is to install just parallel to the wing. What is your experience? Is
putting it some degrees down better to get more accurate values near
stall conditions?
Thomas
433R
Al
Breitbach
Hello,
stab.
stall conditions?
Thomas
433R
