Turning wing
carol51
Turning wing
Post by carol51 » Fri Feb 17, 2012 8:35 pm
Roger 687
Don't worry about bending the spars, they will bend a little.
Two people, one at each end can take hold of the front and rear spar, lift off table and turn over. You might want to pull the rear spar off the table and roll the wing on the front spar
not taking all the weight off the table. You do not have to disassemle the ribs from spars.If you pick the wing up using the rear spar only the spars will bend about 2". this did not bend my spars or do any damage to the ribs. It's good to be cautious but the spars are pretty strong.
Good luck
