How about an O-360 with an electronic ignition and a tuned exhaust? That
should cover all the bases.
I made a tuned system for the Moose, it fits so nicely. Try
www.aircraftexhaust.net 1-800-770-7287 out of Minnesota for some ideas and
how to make a mock-up for them to use as a pattern for fabrication.
Dick Wampach SR-108 N331RW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rob
Maxwel
Sent: Wednesday, August 18, 2010 6:47 PM
Subject: [rebel-builders] O320 or O360 for the Elite tailwheel?
Hi All
My building partner and I have purchased an Elite from Tulsa. It is in
transit to New Zealand at the moment, looking forward to its arrival. We are
going through the process at the moment of deciding what power plant and
should we go down the EFIS track? Any comments/suggestions.? I have been
told an O320 tuned with electronic ignition will produce close to that of an
O360 with a tuned exhaust. We plan to use the aircraft in the backcountry.
Rob Maxwell
Amberley
New Zealand.
If you plan on putting it on amphibs go with the 360.
Ray
On 8/18/2010 8:07 PM, rwampach@att.net wrote to rebel-builders:
-> How about an O-360 with an electronic ignition and a tuned exhaust?
That
-> should cover all the bases.
-> I made a tuned system for the Moose, it fits so nicely. Try
-> www.aircraftexhaust.net 1-800-770-7287 out of Minnesota for some
ideas and
-> how to make a mock-up for them to use as a pattern for fabrication.
-> Dick Wampach SR-108 N331RW
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf
Of Rob
-> Maxwel
-> Sent: Wednesday, August 18, 2010 6:47 PM
-> Subject: [rebel-builders] O320 or O360 for the Elite tailwheel?
-> Hi All
-> My building partner and I have purchased an Elite from Tulsa. It is in
-> transit to New Zealand at the moment, looking forward to its arrival. We
are
-> going through the process at the moment of deciding what power plant
-> should we go down the EFIS track? Any comments/suggestions.? I have
been
-> told an O320 tuned with electronic ignition will produce close to that of an
-> O360 with a tuned exhaust. We plan to use the aircraft in the
backcountry.
-> Cheers
-> Rob Maxwell
-> Amberley
-> New Zealand.
Ray
That
ideas and
Of Rob
-> Maxwel
-> Hi All
are
been
backcountry.
-> Cheers
-> Rob Maxwell
-> Amberley
-> New Zealand.
Thanks Guys
No it wont be on floats however as we know there is no substitute for
power.
Cheers Rob
Sent: Friday, August 20, 2010 3:59 AM
Subject: RE: [rebel-builders] O320 or O360 for the Elite tailwheel?
power.
Cheers Rob
Ray
That
ideas and
Of Rob
-> Maxwel
-> Hi All
We
are
been
of an
backcountry.
-> Cheers
-> Rob Maxwell
-> Amberley
-> New Zealand.
