[rebel-builders] Fw: Fuel tank screen
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 9:31 pm
See http://www.aircraftspruce.com/catalog/a ... ainers.php
Pro Seal will handle those.
Ron
N254RM
On Sun, Aug 8, 2010 at 2:05 PM, Andrew Burr
<verticalperformance@yahoo.com>wrote:
Can any one tell me were to buy the fuel tank screen fittings. I'm in the
process of fixing my one fuel tank. One of the previous owners used tank
sloshing sealer on the tank and the screen is coated with the sealer.
Word of advise don't use tank sloshing sealant on your tanks. luckily most
of it is pealing off but what a mess. I also need to know if Pro seal will
hold up to car gas and ethanol. Some of the places I fly to don't always
have Avgas.
Andrew E Burr XIV
Vertical performance LLc
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and
holds ownership of all intellectual property for each component.
David A. Ricker
Post by David A. Ricker » Sun Feb 19, 2012 9:31 pm
Hi Andrew
There's a lot of discussion in the mailing list archive about Pro-Seal,
Mogas and sloshing compound. I believe there are Proseal/Sealmaster
etc. compounds made especially for Mogas. Lots of discussion about
reasons to not use sloshing compound too.
You will probably find more info there than you will ever want to read
through ;-)
Elite583.cjb.net
Andrew Burr wrote:
Can any one tell me were to buy the fuel tank screen fittings. I'm in the process of fixing my one fuel tank. One of the previous owners used tank sloshing sealer on the tank and the screen is coated with the sealer.
Word of advise don't use tank sloshing sealant on your tanks. luckily most of it is pealing off but what a mess. I also need to know if Pro seal will hold up to car gas and ethanol. Some of the places I fly to don't always have Avgas.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and holds ownership of all intellectual property for each component.
Checked by AVG - www.avg.com
Version: 8.5.441 / Virus Database: 271.1.1/3059 - Release Date: 08/08/10 17:57:00
Andrew Burr
Post by Andrew Burr » Sun Feb 19, 2012 9:31 pm
Thanks Ron!!
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
--- On Sun, 8/8/10, Ron Shannon <rshannon@cruzcom.com> wrote:
Subject: Re: [rebel-builders] Fw: Fuel tank screen
Date: Sunday, August 8, 2010, 9:15 PM
Ron
N254RM
[quote]
Andrew Burr
Dave,
Thanks, so far I'm 8 hours in to cleaning the tank and still more to go. I like to land at a lot of rivers were Avgas is unavailable but Mogas is.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Date: Sunday, August 8, 2010, 11:48 PM
Hi Andrew
Post by Ken » Sun Feb 19, 2012 9:31 pm
PRC told me 20% alky won't hurt proseal and somewhat higher is OK. My
limit is 10%. Of course if it separates it may slowly eat the proseal
but the engine would also quickly stop. My rule is to have it gone
within a day or two. Usual caveats apply.
There are more sources of non alky fuel than some folks think. Marinas,
farm suppliers, premium fuel in some states, airnav.com, and the puregas
website.
the sealer.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Andrew Burr
Thanks Missouri has a state mandate that all gas has to have 10% Ethanol. I almost always have some Avgas in the tank when I need to use Mogas. Which helps a bunch I think.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Date: Monday, August 16, 2010, 12:56 PM
website.
Andrew Burr wrote:
[quote]Can any one tell me were to buy the fuel tank screen fittings. I'm in
the sealer.
Andrew E Burr XIV
Po Box 213
Cassville MO
