[rebel-builders] Firewall material for Reb #786 (manufactured 2003-
Posted: Sun Feb 19, 2012 6:31 pm
O.K. Thanks to all for your responses...the evidence appears to be mounting
that, based on production number, I indeed have a stainless firewall. While I
don't have a piece of stainless to use as "standard", I like Dave's idea to
apply heat to the different drill chips and observe the results. When the time
comes to drill into this thing, I'll pay close attention to the degree of difficulty
in drilling new holes, and collect drill chips for Dave's experiment.
Build on!
Rob
On 8/4/2010 8:06 AM, bobp@prosumers.ca wrote to rebel-builders:
-> Hi Rob !
-> As i recall, the stainless plate was .018 thick - should be
-> easy to mic a part of it .... and it IS very hard to drill !
-> The fix was to add a flat plate of stainless to the front
-> of the aluminum firewall - made for a stronger firewall.
-> This was much easier than using a complete, formed
-> and punched firewall.
-> As Ken mentioned, some builders just added a layer
-> of FiberFrax from Spruce, held on with their Silica adhesive,
-> and coated with the Silica to prevent soaking up oil later.
-> This was light weight and effective - some still flying after
-> over 15 years ...
-> ......bobp
-> bobp@prosumers.ca
-> http://www.amway.ca/BobPatterson
-> http://bpatterson.qhealthbeauty.com
-> http://apatterson2.ordermygift.com
-> Any views expressed in this message are those of the individual sender
-> and do not necessarily reflect the views of any other entities or persons.
-> Any action taken as a result of the contents of this email is totally the
-> responsibility of the reader.
-> On August 4, 2010 09:10:59 am schaumr@dcsol.com wrote:
-> > All
-> > I confirmed last night that my firewall is indeed aluminum (probably
0.032)
-> > (i.e. not magnetic and easily 'test filed".
-> > Ken's email below suggests "early" kits were aluminum, but mine is
-> > #786....hardly an 'early' production number. Should I even bother asking
-> > MAM for the requisite stainless plate? If I have to order this myself, how
-> > thick must this piece of stainless be?
-> > Fortunately, only the witches-hats are riveted on the firewall, and I was
-> > planning on removing them anyway for Wayne's prescribed firewall
-> > reinforcements....so retrofitting the stainless plate is probably the
-> > easiest thing I've had to do on the plane in a long while. How
-> > refreshing.
-> > I dread cutting the stainless though.....it's going to totally dull my
-> > favorite Lennox metal bandsaw blade....sniff.
-> > Rob
-> > Rebel 786
-> > On 8/4/2010 4:28 AM, klehman@albedo.net wrote to rebel-builders:
-> > -> Curtis
-> > -> Some of us riveted a thin flat sheet of stainless on the forward side of
-> > -> the aluminum. Actually makes for a stronger firewall with a little less
-> > -> risk of damage I'm told.
-> > -> I understand that fibrefrax cloth also meets the requirement. It and
-> > -> glue is available from Spruce. I did not use it because I figured it had
-> > -> to be covered with something else anyway to keep it from eventually
-> > -> becoming saturated with oil.
-> > -> I don't know why MAM considered aluminum acceptable for early kits.
-> > -> Ken
-> > -> Curtis Langholz wrote:
-> > -> > Rob, Great topic for sure.... I purchased kit # 175r that had been in
-> > -> > storage for a long time. When I purchased it I bought the upgraded
-> > -> > manuals from MAM and got a tour of the factory plus talked to Daryl
-> > -> > about my engine choice. He recomended the 3" shortening of the
boot
-> > -> > cowl which I did as well as the fload stiffeners and motor mount
-> > -> > doublers. I was feeling really good now that it was complete.... I
-> > -> > check the MAM bulletins regurlarly as well and there has not been
any
-> > -> > mention of the firewall being aluminum or stainless. It is very
-> > -> > frustrating to have all this time putting it together to find out MAM
-> > -> > was so cheap to use an aluminum firewall that is a safety hazard.
Can
-> > -> > anyone give me a suggestion of what I should do with it at this
-> > -> > point? Although it is a setback in the building process, it does
-> > -> > need to be addressed. Thanks for bringing up the question about
-> > -> > firewall material.
-> > -> > Curtis
Build on!
Rob
-> Hi Rob !
-> ......bobp
-> > All
0.032)
-> > refreshing.
-> > Rob
-> > Rebel 786
-> > -> Curtis
-> > -> Ken
boot
any
Can
-> > -> > Curtis
