[rebel-builders] Firewall material for Reb #786 (manufactured 2003-2004)?
Posted: Sun Feb 19, 2012 6:31 pm
Of course aluminum is also non ferrous. Stainless is much heavier, often
has very sharp edges and is hard enough to tell the difference with a
file. It also has a slightly darker gray color.
On 8/3/2010 11:01 AM, Ted Waltman wrote:
Just test with a magnet
On Aug 3, 2010 12:59 PM, "Dick Wampach"<rwampach@att.net> wrote:
Rob, I doubt that any manufacture would make a f/w that was not to
standards for heat resistance.
You could try to test the material with a file, if an edge is accessible in
a non critical location. Alum is soft, SS is much harder, you should be
able to tell the difference with just a few strokes.
Dick
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of...
schaumr@dcsol.com
Sent: Tuesday, August 03, 2010 9:53 AM
Subject: [rebel-builders] Firewall material for Reb #786 (manufactured
2003-2004)?
Hi All,
All th...
Unsubs...
