split flaps
Posted: Fri Feb 17, 2012 11:35 pm
G'day Ian
I read the e-mail Bobp sent you on split flaps. I just wanted to tell you about an incidence I have had during a crosswind.
There have been times that I have held full aileron deflection to bring my upwind wing down. One time during a formation landing with Len in his Cessna 150, we encountered a right crosswind. Just as we were crossing over the numbers, my right wing went up. I immediately threw in full right aileron, but the wing was still not going down. We were at about 20 ft AGL and I knew I had no recovery time if it decided to go over, so then I kicked right rudder and that brought it down. Even though I was 45 degrees to the runway then, at least I had things under control.
The roll response in a Rebel is much better than a Cessna and so is the rudder authority. I don't know what type of shape I would have been in if I were flying a Cessna, but thank God I was in a Rebel. If you are going to try split flaps, take Bob's advise and set yourself up for an easy conversion back to flaperons.
Rick Ford
Rebel436
Rick Ford
Rebel436
