If you have oversized a rivet hole, is the normal practice to insert a 5/32
cherry rivet, or to drill out to the even bigger 3/16. I noticed on a couple
of other builds that the replacement rivet was smaller than 3/16 but had to
be larger than 1/8. Decided to replace the fus 26 with .032 so had to drill
out all the rivets... now left with some oversized holes.
Roland
R56
Rivet Size
bransom
Rivet Size
One can also get 5/32 Avex rivets. A little harder to find. Some kind soul on
this list provided some to me a long time back. Happy to say I've needed
very few. On drilling out, I often use a snap punch to get the center out
after drilling off the head. And in many cases, we really aren't working with a
closed system yet and can get a pair of pliers on the inside mandrel.
Very good work tho, that you're paying attention to getting a full rivet into
the re-drilled holes.
I haven't bought from these guys --
http://www.crawfordproducts.com/avex.htm -- but worth noting here or
similar the max hole size.
-Ben/ 496R
On 7/2/2010 7:11 PM, kriening@rogers.com wrote to rebel-builders:
-Ben/ 496R
Roland
R56
