I'll see if I can make a decision here soon. Then you won't be hanging.
If nothing else, you could use my set to make yours.
On the flaperon re-rivet: after I built mine, someone told me to CS the
rivets around the leading edge because they'd rub against the rear spar
after they were covered. I cn't tell yet if that'll be an issue. Just a
thought. Craig
Original Message:
n715ta@comcast.net
Date: Sun, 4 Jul 2010 09:36:27 -0500
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] Strut farings
Craig - thanks for the offer - There hasn't been any offers! So I'd like to
take you up on your offer if you do not use them.
Are they fiberglass or aluminum? My instruction manual doesn't give material
or dimensional specifications so I've been thinking of making a set using
clay to sculpt a smooth transition around the strut bolts then molding a
fiberglass shell.
Having your's would save me a bunch of time, however! Right now I'm
re-building the flaps and ailerons as they were built with standard pop
rivets and I'd like to change to flush rivets so I can fabric cover without
bumps.
Anyway - if you decide to not use your fairings let me know.
Tom Anderson
C77 - 259mr
N743ta@comcast.net
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of craig
Sent: Wednesday, June 30, 2010 2:38 AM
To:
Subject: Re: [rebel-builders] Strut farings
Did you get any takers on the fairings? I might not use mine; if I don't,
you can have them. Let me know. Craig
n715ta@comcast.net>
To: <
rebel-builders@dcsol.com>
Sent: Thursday, June 24, 2010 6:14 PM
Subject: [rebel-builders] Strut farings
Do any of you have any extra strut farings? My kit (R259) did not have
any.
Instructions do not give dimensions so I'm having problems making.
Tom
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
myhosting.com - Premium Microsoft
