[rebel-builders] Conical vs. Dynafocal
Simon Smith
Post by Simon Smith » Sun Feb 19, 2012 9:24 pm
Roland,
Be careful of the 0-320-B1A dynafocal case engines as they have a different
mounting angle than the MAM mounts.
Si
R555 & R572
Sent: Tuesday, June 29, 2010 8:38 PM
Subject: [rebel-builders] Conical vs. Dynafocal
Not knowing much about engine mounts I thought I would post this for some
responses. Some Lycoming engines such as 0-320B1A use a conical and others
use a dynafocal ? mount. When building our Rebels is one preferred over
other or does it not make a difference. The mounting attach points on the
firewall would be in the same place regardless.
That being said, does anyone have experience with the B1A version... good
bad other.
Roland
R56
Checked by AVG - www.avg.com
Version: 8.5.439 / Virus Database: 271.1.1/2970 - Release Date: 06/29/10
06:35:00
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 9:24 pm
The O-540 series engine has a removable (4 stud) mount casting that bolts to
the 4 corners of the rear case halves. Two come to mind, one is at an 18*
angle and the lugs merge at about the crank shaft flange. The others are
30* and merge at about the center of the crankshaft. The Dynafocal rubber
mounts are not interchangeable. The SR- series welded mount comes with
only the 30* dynafocal type mount. It uses Four Rubber Units Lord P/N
J3804-20, used on Piper PA-23,-24,-25 series aircraft and other makes.
www.lordmpd.com
The castings are referred to as type A, or type B, I do not recall which is
which.
The engine I am using from a R-182 (RG) O-540-J3C5D used an 18* mount as
most all Cessna six cyl's do. I went to a 30* mount castings from a Piper.
I may be wrong in saying that almost all of the bigger 4 cylinder Lyc.
engines use conical mounts. The "lugs" are cast into the 4 rear corners of
the case halves and are not removable. I do not know what the O-235 uses.
About 5 years ago Nancy sent me information on the only two mounts that
Murphy sells...one conical for the 4 cyl, & one dynafocal 30* for the 6 cyl.
I hope this helps...
Dick Wampach SR-108 N331RW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Simon
Smith
Sent: Tuesday, June 29, 2010 8:53 PM
Subject: Fw: [rebel-builders] Conical vs. Dynafocal
Roland,
Si
R555 & R572
some responses. Some Lycoming engines such as 0-320B1A use a conical
and others use a dynafocal ? mount. When building our Rebels is one
preferred over the other or does it not make a difference. The
mounting attach points on the firewall would be in the same place
regardless.
good bad other.
Roland
R56
06:35:00
password "builder"
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 9:24 pm
Thanks all for the quick responses. I had the opportunity to buy a low time
B1A at a reasonable price. Turns out he is selling as the engine
dimensions... setup, will cause problems with his nose gear and cowl on an
RV. After all of the comments, decided to pass on this one. I will continue
on looking and waiting for the 'right' engine option ( as if there really is
just one !).
Roland
R56
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dick
Wampach
Sent: Wednesday, June 30, 2010 1:12 AM
Subject: RE: [rebel-builders] Conical vs. Dynafocal
www.lordmpd.com
which.
Smith
Roland,
Si
R555 & R572
regardless.
good bad other.
Roland
R56
06:35:00
password "builder"
