[rebel-builders] Airbox
Posted: Sun Feb 19, 2012 9:24 pm
Craig,
Just wondering what you and others are using for an airbox on the Lycomings?
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_5
Subject: Re: [rebel-builders] Need Prop Spacer
Date: Tue, 15 Jun 2010 18:54:43 -0800
Thanks Wayne, it is a 180 hp. It's Dennis Findley's old 130 hr Aerosport
0360. Regarding the spacer, I thought the machine shop charge would be more
than the shipping to swap. Walter, I am using that cowl. I didn't have the
spinner or the airbox when I started fitting it. I should have been
thinking about three areas as I worked--the airbox, the spinner, and the
attach points. Another thing I've noticed is that the carb seems to be
offset slightly to the pilot side. Approx 1/2". That will take some
re-working too. Craig
On a side-note, I met up with Jay Yau in Palmer today. He was weathered in
waiting to fly to Mccarthy. I got to study his plane in depth and I have to
say that it is very nice. He's very happy flying it up here and it was a
good shot in the arm for me. I only wish it hadn't been packed full and I
could have begged a flight! Thanks, Jay.
Sent: Tuesday, June 15, 2010 5:48 PM
Craig.. figure out exactly what you need without having to play with the
cowling etc... and then take it down to the local machine shop. Pop the
locating pins out and mill or turn the forward face down to the thickness
you need for less than the postage of swapping someone.
1/2" bolts... you putting an O-360 in it?
Sent: Tuesday, June 15, 2010 9:42 PM
Subject: [rebel-builders] Need Prop Spacer
It looks like I'm going to need a 2" spacer for my prop set-up. I have a
2.5" and somehow I ended up with a 1.5" gap between my front cowl and
spinner. Not sure what happened but I did follow the MAM cowl
instructions. Maybe they are not made for a 2.5" spacer. Anyhow, I can
make up a 1/2" at the spacer and another 3/4" where the cowl attaches at
the firewall. That will leave around a 1/4" gap. Luckily I have a good
sized lip at the back to trim.
Anyhow, the prop is a Sens 74-56 w/ 1/2 bolts. I'd like to swap with
someone rather than have to buy one. I'm guessing that they are not
cheap. Anyone have one they don't want or know of one? Thanks, Craig
