Float Fix Gussets
Posted: Fri Feb 17, 2012 11:34 pm
Your following message has been delivered to the 172 members of
the list murphy-rebel@dcsol.com at 09:13:31 on 14 Dec 2000.
Bruce, there may only be one Rebel that MAM "claims" to know about, but
unless Darryl shred it he has a 3 or 4 page dissertation from me in his
files describing how I sheared EVERY rivet out of my passenger door post
(and the top 5 out of the pilots side) from the top all the way down to the
wing strut attach fitting (while flying on skis in 1996). Just like opening
up a can of sardines!! I tried to get the equivalent of the "float fix
bulletin" issued back then to no avail, and it didn't actually come about
until aircraft were damaged, in front of the "world", at Oshkosh!
My fix was (and still is) to drill for and install another staggered row
(mid point between the existing rivets and forward or rearward enough to
just catch the tube without hitting the outside wall) of stainless RR5404
rivets up the door post (carry through) with the top four original holes
being enlarged to #11 for 3/16 Stainless Rivets so the guillotine action
can't get started. This has held up so far on all the Rebels I have worked
on. If the windshield is already in place you can't really do the gusset
thing. If the windshield isn't already place, I would do the gusset plate as
this puts a nice size Band-Aid right were the shearing of rivets wants to
start. (The SR2500 has a huge plate/gusset put here).
FWIW, MOST "fixes" I offer to this list aren't theoretical folks! I have
been nice enough to bust up my aircraft for you (as have others like
Allister) to develop them so your's stays together!
Sent: Thursday, December 14, 2000 12:47 AM
Subject: Re: witches hat install
Wayne,
How important are the gusset plates at the top of the front and rear door
post, on MAM float fix? The new manuals only show the 2" channel between
engine mounts, but the SB show the channel "and" the gusset plates. Brian
G.,
at MAM, told me only one Rebel on floats ever had a problem at the door
post
and it was landing in to rough of water.
Bruce G 357R
Contributors' page at:
Visit the book store at:
Float Fix Gussets
by Keith Mint
Would this work on the Elite also
Keith B. Oliver
Elite N654ME
From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
Sent: Thursday, December 14, 2000 8:38 AM
Subject: Float Fix Gussets
Wayne,
G.,
post
Bruce G 357R
Float Fix Gussets
the list murphy-rebel@dcsol.com at 12:00:32 on 14 Dec 2000.
Don't see why not Keith although, if you can, I would definitely put the
gusset plate at the upper door post area to help hold it together (in
addition to the staggered rivet row) with the extra weight on the nose of a
Lyco 360 (if that is the route you are, or have, gone). MAM's "float fix"
also tells you to do a doubler plate around each of the rear wing attach
fittings as in a really hard pounding on floats, there is of course the
opportunity for the rivets to shear here also, as the floats "stop" and the
tails momentum wants it to keep going downwards, just like the engine/nose
section compared to the door post. On Howard's (and others) I have doubled
the rivet count on the two bulkheads at the rear wing attach (because he
didn't want me to pull the wings) by drilling and riveting from the inside
of the cabin, and so far so good. On Bob P's XWI, I made a large plate that
goes from the root gap fairing box to beyond the torque tube hole, with lots
of rivets to tie it all together. Probably overkill, but it will definitely
never come apart there!
I have never "viewed" an Elite construction manual (or worked on one), so
these items <MAY> be addressed in it differently than with the Rebel. (but I
doubt it!)
Sent: Thursday, December 14, 2000 10:19 AM
Subject: RE: Float Fix Gussets
Keith B. Oliver
Elite N654ME
opening
as
Wayne,
door
Brian
G.,
post
Bruce G 357R
Float Fix Gussets
Posted: Fri Feb 17, 2012 11:35 pm
by Bob Patterson
Keith,
ABSOLUTELY !! As I recall, the Elite had problems in this area,
at Oshkosh, as well, and needed a replacement windshield ....
I believe that <all> of the 'floatfix' items would be "Good Things"(tm)
to do for the Elite, as well !!
-------------------------------orig.-------------------------------------------
At 10:19 AM 12/14/00 -0500, you wrote:
Would this work on the Elite also ??
Keith B. Oliver
Elite N654ME
Wayne,
G.,
post
Bruce G 357R
Float Fix Gussets
Your following message has been delivered to the 171 members of
the list murphy-rebel@dcsol.com at 15:13:36 on 14 Dec 2000.
Glad <YOU> mentioned the factory Elite as I was avoiding the full finger
point in my plural of airplanes, even though I knew it was the other
airplane involved! I learned of the incident the day Les McInnus got home
with his Rebel (after using a turnbuckle and some other gismos to push his
motor mounts back into place so he could fly it home), as he called me to
apologize for not listening to me when I had previously offered to fly down
to Hamilton and reinforce his firewall during his engine upgrade to an
O-320. He was convinced by other Rebel builders/flyers that it wasn't
necessary and suffered damage to his aircraft in a very inconvenient place
to work on a plane (Oshkosh).
Do the reinforcing now everyone, as it's much easier before the damage as a
retrofit to a flying bird, or while you are building it the first time!
P.S. JUST TO TEASE YOU ALL! I just came back from an hour or so of playing
in 3 feet of powder snow, with my wheel ski equipped Rebel. I had to remind
myself why I do more flying in the winter, than any other time of year!
EVERYTHING WHITE IS A RUNWAY!!!!!!
Sent: Thursday, December 14, 2000 1:25 PM
Keith,
Things"(tm)
Keith B. Oliver
Elite N654ME
opening
worked
as
Wayne,
door
between
Brian
G.,
post
Bruce G 357R
Float Fix Gussets
the list murphy-rebel@dcsol.com at 15:55:06 on 14 Dec 2000.
Yah, well don't feel too bad! That hour today only brings my total time for
November and December to a "high" of 3.8 lowsy hours!!!!!!! And 1.8 hrs of
those were flights to inhibit the UTVA's engines for the winter at 0.9 each!
Really sucks when I only have to walk 90 feet and open the door to the
hanger and I still can't find the time!
Sent: Thursday, December 14, 2000 3:31 PM
Subject: Re: Float Fix Gussets
OOOHHHHH !!! That DOES hurt !! Been too busy to
even go up & sweep the snow off ... (sigh)
his
down
place
playing
remind
Keith,
Things"(tm)
but
his
post
opening
about
row
RR5404
holes
action
worked
gusset
plate
as
have
door
between
Brian
door
Float Fix Gussets
by Bob Patterson
Keith,
Things"(tm)
Keith B. Oliver
Elite N654ME
opening
worked
as
door
between
Brian
G., post
Float Fix Gussets
Your following message has been delivered to the 166 members of
the list murphy-rebel@dcsol.com at 23:04:57 on 14 Dec 2000.
Trust me Brian, it REALLY broke my heart the day I turned my Rebel into an
opened sardine can! Luckily I did it in front of my father-in-laws
waterfront home and he had a full 60 of rum on hand! The next day I figured
how to patch it together for the 1/2 mile flight home to the field, for
proper inspection and repairs. Amazing what you can do in a pinch, with a
hand full of rivets and a roll of duct tape!
Take care,
Sent: Thursday, December 14, 2000 10:45 PM
Hi Wayne
That is mighty big of you to break & bust your aircraft so that others can
benefit from your grief!
I wish I was as noble as you but I'm too lazy. And it would break my
heart.
Obviously, the weaknesses that you and others have pointed out really help
us all make
the Rebel a better aircraft. It is great that we have this site to keep
info flowing.
Best Regards
Brian #328R
opening
as
Wayne,
door
Brian
G.,
post
Bruce G 357R
Float Fix Gussets
by rebelair
Hi Wayne
I wish I was as noble as you but I'm too lazy. And it would break my heart.
us all make
the Rebel a better aircraft. It is great that we have this site to keep the
info flowing.
Best Regards
Brian #328R
Wayne,
G.,
post
Bruce G 357R
