[rebel-builders] Good day all, Moose question
Posted: Sun Feb 19, 2012 9:24 pm
by Bob Patterson
Hi Kelly !
The idea of mass balance is to balance the weight of
the control surface, so it doesn't want to drop ....
usually one just adds enough weight to equal about 60 or
70% of the weight, so it still falls, but slowly.
Having too much weight on a horn is just as dangerous as
not enough !
The easy way to tell is to disconnect the aileron completely,
and lift it & drop - it should fall slowly to full down - or at very least,
to neutral .... If it doesn't, there's a good chance you have
too much weight !!
bobp@prosumers.ca
responsibility of the reader.
On June 8, 2010 11:41:12 am Kelly M. Ewing wrote:
I have installed the weights in the aileron tips and now the ailerons are
both high when the stick is in neutral. I did the adjustment prior to
installing the tip weights and everything was good, now it looks as though
I need to readjust. ? Anyone have this happen or am I missing something.
Secondly does anyone know the exact weight of the lead in the tips? Maybe I
have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
by Kelly M. Ewing
Thanks bob I had no idea, just a feeling it may be too much weight. Thanks for info and I will go through that process.
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
Date: Tue, 8 Jun 2010 12:22:15
Subject: Re: [rebel-builders] Good day all, Moose question
Hi Kelly !
not enough !
too much weight !!
bobp@prosumers.ca
have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
by Kelly M. Ewing
Bob ! Way too much weight !
kelly@tru-form.ca
Enjoy your day !
Hi Kelly !
not enough !
too much weight !!
bobp@prosumers.ca
have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
by Kelly M. Ewing
Also Ted has a point I wasn't aware of, I did just check, A little play in the ( I think ) torque tube.
Thanks guys
Kelly
Moose
kelly@tru-form.ca
Enjoy your day !
Date: Tue, 8 Jun 2010 16:34:51
To: MAM email list<rebel-builders@dcsol.com>
kelly@tru-form.ca
Enjoy your day !
Hi Kelly !
not enough !
too much weight !!
bobp@prosumers.ca
have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
by Bob Patterson
Good that you caught it Kelly !
Maybe the weights you have were meant to be cut in half ???
bobp@prosumers.ca
kelly@tru-form.ca
Enjoy your day !
Hi Kelly !
not enough !
too much weight !!
bobp@prosumers.ca
though I need to readjust. ? Anyone have this happen or am I missing
something.
I have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
by Kelly M. Ewing
Yes I think that is the case,
Thanks again
Kelly
kelly@tru-form.ca
Enjoy your day !
Date: Tue, 8 Jun 2010 14:58:23
bobp@prosumers.ca
kelly@tru-form.ca
Enjoy your day !
Hi Kelly !
not enough !
too much weight !!
bobp@prosumers.ca
something.
I have too much?
Thanks kelly
Moose
kelly@tru-form.ca
Enjoy your day !
