[rebel-builders] prop spacers
Posted: Sun Feb 19, 2012 9:23 pm
by Drew Dalgleish
I don't have a spacer on my prop with a piper tri pacer nosebowl. If you
have the speed cowl I think you need one.
At 04:22 PM 03/06/2010 -0400, you wrote:
Hi all
Does the rebel with 0-320 require a spacer to put spinner and prop clear of
the nose bowl, how much of a spacer is needed
Is it possible to push cowl and nose bowl back far enough so a space is not
needed
mike
by Angus McKenzie
I have an extra 2" prop spacer.
Came with the 80"Borer I bought. I had a machine shop counter-sink all the holes for the prop flange so I would not have to use it. The correct bolt kit was priced at $650 for the 6+" AN bolts
Date: Fri, 4 Jun 2010 00:25:43 -0400
Subject: Re: [rebel-builders] prop spacers
Hi all
needed
mike
by Jones, Michael
So aree you selling the 2" spacer, my prop has 3/8 bolts, how do I know
if your spacer will work ?
mike
Angus McKenzie
Sent: June 4, 2010 8:08 AM
To: Mike Davis
Subject: RE: [rebel-builders] prop spacers
you
Hi all
clear of
is not
needed
mike
by Angus McKenzie
So yes, I'll sell the 2"spacer. I'll have to go to the hangar (Sun.) and measure the bolt size but I think it's 3/8th's".
Half of AC Spruce price sound OK?
Date: Fri, 4 Jun 2010 08:11:38 -0400
mike
Angus McKenzie
To: Mike Davis
you
Hi all
clear of
is not
needed
mike
by Jones, Michael
Sounds great to me,
what about bolt pattern I have sae2, 3/8 bolts,
When can I pick up,
Contact me at
Michael.jones@snclavalin.com
We can work out the details
cheers
Angus McKenzie
Sent: June 4, 2010 8:22 AM
To: Mike Davis
know
mike
Angus McKenzie
To: Mike Davis
correct
you
Hi all
clear of
space
is not
needed
mike
by Angus McKenzie
Hi Mike, My engine is 0-320-A2B from and American Champion Challenger GCBC and I'm not certain of the SAE pattern, I think it's 3/8" maybe someone will jump in here and tell us so you'll know before I go to the hangar and check the pattern/size.
I'm in St.Thomas at my hangar Sun morning to fly the Rebel to Reeces Corners for the fly-in, be back mid afternoon.
Can mail it if you want
Date: Fri, 4 Jun 2010 08:26:59 -0400
Sounds great to me,
When can I pick up,
Contact me at
cheers
Angus McKenzie
To: Mike Davis
know
mike
Angus McKenzie
To: Mike Davis
correct
you
clear of
space
is not
by Jones, Michael
Check the size and let me know if it will fit, my engine is 0-320 b3b
160 hp, 3/8" prop bolts and sae2 flange pattern
If it all works will take it , mailing is fine or can pick up, either
works
Let me know when you have details
cheers
Angus McKenzie
Sent: June 4, 2010 8:41 AM
To: Mike Davis
Sounds great to me,
When can I pick up,
Contact me at
cheers
Angus McKenzie
To: Mike Davis
know
mike
Of
Angus McKenzie
To: Mike Davis
all
correct
If
you
prop
clear of
space
is not
