torque tubes inside fuselage
Posted: Sun Feb 19, 2012 9:23 pm
i all
i am doing the torque tubes inside the fuselage and am confused, as i go
along i see lots of questions comming
first of all the 2 torque tubes large and small, what is the
relationship of the control arms on the ends, are they exact opposite of
the ends that attach to the wing tubes
if they are identical at each end at what point can i rivet together,
since the inside pieces bolt onto the hanger bracket i assume the tubes
are not removeable and they would be bolted first, then rivet the end
caps to the tubes then mount the hanger bracket after fitting with wings
in place
cheers for now
mike#007
in place
cheers for now
mike#007
