[rebel-builders] Rebel Fuel Plumbing Plan
Posted: Sun Feb 19, 2012 6:19 pm
Thanks Wayne, for the details.
If I'm following your description correctly, your L/R drains are right at the
exterior angle change in the floor. Looking at photos of completed Rebels in
their three-point position, this would appear at first glance to no longer be
the lowest point, as the floor continues to angle downwards towards the tail
in this configuration. However, I can see how careful attention to the angle
at which you bring your lines in from the sides towards the center could
correct for this. I assume you must have also angled the lines from high to
low "within" the floor as well, such that the holes you drill into the channels
get progressively closer to the bottom floor skin as you get closer to the
center. Is this correct?
My personal mission would be to either 1) replicate your line routing to the
center of the aircraft then combine/drain and send a single line forward, or 2)
take each line separately underneath the door sill without any connectors
from the rear window all the way to the foot well, while maintaining an
adequate angle to ensure the low point is in the foot well. Has the latter
ever been done by anyone?
Either way, I am faced with the challenge of routing the 3/8" tubing around
some serious corners. It has been mentioned elsewhere that it is difficult to
push the fuel line through appropriately sized grommets if the angle deviates
significantly from 90 degrees. Ken and others have also suggested hard
plastic "snap-in" grommets with some proseal to lock the line in place. Are
there any lubricants to help make the grommet-job easier? Does everyone
buy a tube bender to avoid crushing in tight corners or is there an effective
alternative?
Thanks!
Rob
Rebel 786
Reading the archives again last night, I
-------- Forwarded Message ---------
Original: DATE..... 4/20/2010 1:23 PM
Original: FROM..... oifa@irishfield.on.ca
alternative?
Thanks!
Rob
Rebel 786
