Parts List for Rebel Needed
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 9:19 pm
Hi Ken,
Checked the archives for the .xls file... did not find it. If you have a
list of parts it would really help me identify which parts are missing or
mis-labeled.
Roland
R56
Sent: Sunday, April 18, 2010 9:20 PM
Subject: Re: [rebel-builders] Bulkhead Stiffeners
Roland
There used to be an .xls spread sheet in the archives with all the rebel
parts listed. Let me know if you can't find it. Wray Thompson did this
many years ago.
Anyone unhappy with bathtub fittings can always weld some up out of
steel sheet if they have a gas or tig torch.
Wayne G. O'Shea wrote:
The four sets that you have are for the engine mount brackets behind the
firewall... but really surprised that your kit doesn't have the original
one
piece fittings for this as well.. The Fus85/86 combo didn't come out to
well
after kit 243 !
Sent: Sunday, April 18, 2010 7:24 PM
Subject: RE: [rebel-builders] Bulkhead Stiffeners
Thanks Wayne, pictures are always helpful. Do you remember a fus 87? The
plans call for one. Should I assume that the fus 87 replaced the fus 86,
in
the tailcone. As I mentioned, I have four of each of these parts... will
need some elsewhere on the plane as well.
If anyone out there has a complete list of parts, numbers and
descriptions... I could use one about now. I only have bits and pieces of
lists from the previous builder, but nothing I would trust as being
comprehensive.
Roland
R56
