Page 1 of 2
[rebel-builders] Static port
Posted: Sun Feb 19, 2012 9:19 pm
by Jay Yau
Does most of you have alternate static source installed in your airplane?
My Rebel doesn't have it, some of my instrument failed during the trip to Alaska last year (I remember it was Airspeed, and possible Vertical speed and Altimeter), I think the moisture (water) got into the static port instead of pitot (come to think of it).
Can any one share the wisdom with me? what's the best way to install a alternate static source? I'm thinking to put a "T" and use an air valve to turn it on and off.
Jay
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
That's what I have Jay... mounted right into the bottom lip of the panel
edge.
Hard to read.. but to the left of the primer..
http://www.irishfield.on.ca/gallery/panels/panel-3.jpg
Sent: Monday, April 12, 2010 11:05 PM
Subject: RE: [rebel-builders] Static port
turn it on and off.
Jay
inbox.
by Jay Yau
Hi Wayne,
Couldn't see it clearly in the picture, is it under Bank & Turn coordinator? do you use a valve to turn it open and close?
Jay
Subject: Re: [rebel-builders] Static port
Date: Mon, 12 Apr 2010 23:12:06 -0400
edge.
turn it on and off.
Jay
inbox.
Yes Jay... a simple drain cock. It's threaded NPT so easy to adapt to a
fitting to connect your tubing to.
Sent: Monday, April 12, 2010 11:18 PM
Hi Wayne,
Jay
edge.
airplane?
speed
turn it on and off.
Jay
inbox.
inbox.
by Michael Kraus
I used this:
http://www.clippard.com/store/display_d ... ?sku=MTV-2
It is manufactured by Clippard and the part number is MTV-2. It looks
just like an aviation toggle switch on the outside, but is a pneumatic
switch. I thought I purchased it from mcmaster carr or grainger, but
couldn't find it online by those numbers....
-Mike Kraus
Sent from my iPhone
On Apr 12, 2010, at 11:23 PM, "Wayne G. O'Shea"
to a
Hi Wayne,
Jay
panel
edge.
inbox.
Posted: Sun Feb 19, 2012 9:24 pm
by Drew Dalgleish
Inside the wing strut is probably better than in the cabin. I have a murphy
pitot tube with the static port built in and it works pretty good.
At 05:24 PM 07/06/2010 -0500, you wrote:
Hello All
I have read everything in the archives about the location of the static port
on the Rebel. The only thing everybody seams to agree on is to vent it
inside the cabin. I am not to sure how well that would go over with the
people who will do the initial and subsequent bi-annual inspection for my
mode "C" transponder? What if I plumbed all the flight instruments and the
encoder together and ran the static line outside and a couple of feet up in
to the left side lift strut with a vented plug in the end? I know of a
couple aircraft that do just that. Would that make a difference? Anybody
tried that?
Charlie E. 802R
by Charlie Eubanks
Thanks Drew
I wish I had the foresight to do something like that before I closed up my
wing. Unless I find something better I guess I will just vent the static up
the lift strut.
Charlie E.
Sent: Tuesday, June 08, 2010 7:34 PM
murphy
Hello All
port
in
tried that?
Charlie E. 802R
by Drew Dalgleish
I installed mine with the wing closed up. It takes about a 1" hole in the
leading edge and another hole in the bottom of the wing right in front of
the strut attach bracket. The hoses run straight back inside the wing then
down the strut and into the cabin. The holes get covered up by the strut
fairings.
At 10:27 PM 08/06/2010 -0500, you wrote:
Thanks Drew
the lift strut.
Charlie E.
murphy
Hello All
port
in
tried that?
Charlie E. 802R
by Gary Gustafson
I have vented my static pick up to inside the cabin and it
reads wrong. I have vents for cooling air into the cockpit.
When I open the vents I read 400 to 500 feet lower than
with the vents closed. I am not sure whether the cockpit is
a bit pressurized, either negatively or positively.
As a result, I have purchased a static port and will be
installing it soon about 1/3 of the way back on the tail
cone. Will try and remember to send the results.
Charlie Eubanks
Sent: Monday, June 07, 2010 6:24 PM
Subject: [rebel-builders] Static port
Hello All
tried that?
Charlie E. 802R
by Jones, Michael
I believe I read in one of the eaa tony bingelis (excuse spelling) books
that you should never use static port that is inside the cabin
Mike#007
Gary Gustafson
Sent: June 10, 2010 11:38 AM
Charlie Eubanks
Hello All
port
my
in
tried that?
Charlie E. 802R
by Ken
My static source works well from inside the
cabin and my local shop is fine with that for transponder certification.
Yes there is a flicker if I change cabin ventilation but the acid
test is cruising just above a runway. If the altimeter reads correctly
then the static source is accurate.
Mike#007
Gary Gustafson
Charlie Eubanks
Hello All
port
my
in
tried that?
Charlie E. 802R
by Charlie Eubanks
That is good to hear. Could you tell us if your instruments ( and endecoder)
are hook up together and then vented through one tube or is each one vented
individually?
Charlie E.
Sent: Friday, June 11, 2010 7:14 AM
Mike#007
Gary Gustafson
Charlie Eubanks
Hello All
port
my
in
tried that?
Charlie E. 802R
by Ken
Hi Charlie
Both are hooked up together to a common tube as a radio shop has to
compare the readings. They will want a single point to connect to as far
as I know.
Charlie Eubanks wrote:
individually?
Charlie E.
Mike#007
Gary Gustafson
Charlie Eubanks
Hello All
port
my
in
tried that?
Charlie E. 802R
by Roger Cole
C-172s and other TC airplanes typically have two static ports: one on
the outside, and one inside the cabin with a valve to select one or
the other. The outside static port is used for normal operation. If
the outside port becomes fouled (by ice, for example) the inside port
can be selected. The Cessna 172 manual warns that the inside port is
not as accurate as the outside port.
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
Charlie Eubanks
Hello All
static port
for my
and the
feet up in
Anybody
tried that?
Charlie E. 802R
by Charlie Eubanks
Thanks Roger
I will be eager to hear what you find. I think Eric Fogel has a similar
location on his Elite. I wonder how well his works?
Charlie
Sent: Friday, June 11, 2010 3:41 PM
Roger Cole
Murphy Elite #709
Charlie Eubanks
Hello All
static port
for my
and the
feet up in
Anybody
tried that?
Charlie E. 802R
