[rebel-builders] pitot tube drain
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 6:19 pm
The pitot is a closed system. There isn't any airflow through it.
Sent: Monday, April 12, 2010 8:10 AM
Subject: [rebel-builders] pitot tube drain
Any one has Airspeed indicator fail when flying in wet country? like to
get a advise for a pitot tube water drain?
Jay
The New Busy is not the too busy. Combine all your e-mail accounts with
Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_4
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 6:19 pm
Normally when installing a pitot line, one installs a T
in the line with a plug in the downward plugged end of
the T so that water will collect there
before draining to the instruments. The plug has to have a
good seal as the pitot system is a closed system. However, if
water gets into the pitot system you want to catch it in the T
before it eventually drains to the instrument (if your pitot is
mounted higher than the instrument). Removing the drain plug
allows you to drain any collected water.
Palmer
Sent: Monday, April 12, 2010 12:20 PM
Subject: Re: [rebel-builders] pitot tube drain
Jay
Hotmail.
http://www.windowslive.com/campaign/the ... cid=PID283
26::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4
Post by Wayne G. O'Shea » Sun Feb 19, 2012 6:19 pm
What Bob said! In flight there isn't any air flow into the tube.. just
variable air pressure.
Depending on where you put the pitot though... when the aircraft is sitting
on the field, in the rain (and condensation), water does find it's way in on
some systems. For that reason I generally put a tee and drop tube with a
plug in it, in the low spot of the pitot line. This lets any moisture
collect where it is easily drained IF necessary and won't effect the A/S
function.
I found this out the hard way.... while at Osh '95 with my Rebel, my A/S had
water in it and I left and flew home without one.
Jay
Hotmail.
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 6:19 pm
My "L" shaped pitot tube under the wing has a 1.5-2 deg negative slope,
along with a rather nigh vertical section running up into the wing, so even
rain water blowing while on the ground will drain in flight attitude.
Condensation is still a potential source of moisture.
I have a "T" in the pitot line at the bottom of the strut, before entering
the cockpit. One 90 deg. side of the "T" makes the necessary turn up to the
cockpit, and the other is capped as a collector/drain. See photo at
http://n254mr.com/node/557
Ron
254R
Jay Yau
Post by Jay Yau » Sun Feb 19, 2012 6:19 pm
Ron,
Your picture tells everything, thanks!
Jay
Date: Mon, 12 Apr 2010 09:56:25 -0700
Ron
254R
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.
