[rebel-builders] RE: Signs of life and cabin roof
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 6:15 pm
Saw a note in your link refering to countersunk rivets not being as strong
as domed rivets. That is true however, dimpled flush rivets (where they can
be used) are as strong or stronger than domed rivets.
Bob.
Sent: Sunday, March 07, 2010 9:53 PM
Subject: [rebel-builders] RE: Signs of life and cabin roof
Hi Mike,
Here are a couple notes and pictures of my cabin roof work in case
anything
here might be helpful. Note the liberal tape usage to hold things down
before drilling holes.
http://mae.ucdavis.edu/ransom/Murphy/20 ... 2/0802.htm
I'm not sure I even read other advice about holding off putting in the
rear
wing attach brackets, but I wasn't brave enough to do it before wing
rigging
(which I've still not done). I did however, stack up the brackets,
sandwhiched them between the two bulkheads and made careful placement
measurements so that I could cut the slots for them to stick out of
Fus-27.
This allowed me to finish off the rear "float fix doubler bulletin" in
that area,
and basically, it's all ready for final bracket hole drilling when I
eventually get
to wing rigging.
-Ben, 496R
On 3/5/2010 12:53 AM, mikeh wrote to Rebel builders:
Hi all,
Hoping to promote some discussion which might help enliven things on
the site and help some builders........... like me.
I have the cabin roof in place, drilled and cleco'd to the top carry
through FUS 3 only. I need to do some aligning of bulkhead and root rib
flanges to make a nice job of it. Possibly joggling the bulkhead flanges
at
the root rib will help.
I'm sure I'll sort it out but has anyone any advise that might
assist?
I'd be grateful. Any comments on the cabin roof generally would also be
gratefully received.
A bit further on is fitting the rear wing attach brackets,
sandwiched
between two bulkheads. There has been discussion in the past about
leaving
the positioning of the brackets until the wing is being fitted so the
angle
of incidence can be set correctly. This makes sense to me. Does anyone
have
a comment on this?
Cheers and thanks, keep up the good work Mike
Post by Ken » Sun Feb 19, 2012 6:15 pm
They may be as strong but they will rip out of .020 sheet much easier
than the dome rivets. Wayne has seen the results and I have confirmed
what happens with testing. I use them happily in most situations though.
Bob.
bransom
Post by bransom » Sun Feb 19, 2012 6:15 pm
Makes me wonder if solid flush rivets might rip out of dimpled 020 just as
easily as Avex CS rivets (again, dimpled 020). I really don't want to go
there. IIRC, the AVEX to solid conversion chart supplied by MAM (and
probably originally by AVEX) gave concern only to meet or exceed sheer
strength for whatever the stacked thickness of pieces being riveted. I.E.,
didn't address the issue of thickness of that top skin per se.
I'd like to say I won't lose any sleep over it, but then testing on a sample
does start to seem like a reasonable idea.
-Ben
On 3/9/2010 3:52 AM, klehman@albedo.net wrote to rebel-builders:
can
Bob.
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 6:15 pm
Ben,
With regards to strength: Machined CS vs Dimpled holes for flush rivets.
The dimpled holes will be stronger than the machined holes.
Hope that makes you sleep a little better. But then again, there are
minimum thicknesses of material to Machine CS a hole and that is also
dependent on which rivet you are using, 100* or 120*. Dimpling a hole is
usually done because material is too thin to Machine CS.
Jeff
sample
-Ben
strong
can
Bob.
Bob Palmer
"Dimpling a hole is
usually done because material is too thin to Machine CS."
Exactly, in fact for a 1/8 rivet .032" is the minimum thickness, otherwise
you will enlarge the hole and further weaken the joint. Most of the strength
in any rivet joint is in the shear otherwise it would be bolted.
Bob.
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Tuesday, March 09, 2010 4:56 PM
Subject: Re: [rebel-builders] RE: Signs of life and cabin roof
Ben,
Jeff
as
I.E.,
sample
-Ben
though.
Bob Palmer wrote:
strong
can
