[rebel-builders] windshield retainer screws
Posted: Sun Feb 19, 2012 9:03 pm
I have same situation on my widshiel and don't know what to do with it
Mike#007
Ron Shannon
Sent: February 24, 2010 11:33 PM
Subject: [rebel-builders] windshield retainer screws
The good news is the windshield is mounted and generally looks great,
with
one exception. I'm using the factory-provided dual flanged metal strips
for
the side and top windshield retainers, with the wide flange to the rear,
screw holes through the wide flange. The screw heads are at quite an
angle
to the rear flange, which is itself at an angle to fuse, of course.
Because
they're at quite an angle, the screw head edges are only loading the
forward
side of the wide flange bearing surface.
Any suggestions for getting the screw heads to sit flatter on the
flange? I
have seen this same configuration on other Rebels where the screw heads
seem
to draw down quite flat on the rear flange, but haven't figured out how
do it. (I have a hunch this shouldn't be a mystery, but concocting
mysteries
where there shouldn't be any is one of the few things I do well.)
With regular head screws (i.e., not truss head) on top of nylon washers,
head-to-flange angle looks a little better, but the only other option I
can
think of that might work would be to custom bend a Z-step retainer like
some
others have used.
254R
Mike#007
Ron Shannon
with
for
angle
Because
forward
flange? I
seem
mysteries
can
some
others have used.
254R
