[rebel-builders] prop bolt sizes
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:03 pm
Call the guys that built if for you and see if Greg will trade you a set of
3/8 bushings...and tell you how to change them..... since they cost $40 or
so EACH ! Why I wish you hadn't gone direct as these things get taken care
of when I play middle man.... :O)))
Sent: Tuesday, February 09, 2010 4:57 PM
Subject: [rebel-builders] prop bolt sizes
Hi all
I guess I have a problem with my prop and prop flange
Prop says on it to use an6 (3/8) bolts
But when engine was built it had an7 (7/16) lugs installed
So questions is can I change out the lugs for smaller size or does a shop
have to do it, assume they are a press fit, is there special tool to use
besides a sledge hammer
Perhaps wayne you can tell me size for your prop lugs since we have same
engine, except for the 160 hp in mine
Mike#007
mike jones
Post by mike jones » Sun Feb 19, 2012 9:03 pm
Yep I know wayne
But I did not have the prop then, I just got it and got what I think is good
price for it, especially when I see some going for 1200-2000
mike
G. O'Shea
Sent: Tuesday, February 09, 2010 5:20 PM
Subject: Re: [rebel-builders] prop bolt sizes
Hi all
Mike#007
There are so few props out there for O-320's with 7/16 bolts..... that I
always change the bushings to 3/8, when I have engines built, because of the
massive selection of new and used props for O-320's with that diameter bolt.
Other issue is if you start with a 3/8 bolt prop.. you have that same
massive market to sell to if you want to change it out. If you have a 7/16
prop.. market is darn limited.
If Greg has a set there.. don't think he'll make a big stink swapping.
Sent: Tuesday, February 09, 2010 5:23 PM
Subject: RE: [rebel-builders] prop bolt sizes
Yep I know wayne
good
mike
G. O'Shea
Hi all
Mike#007
