[rebel-builders] control column rotation
Posted: Sun Feb 19, 2012 9:02 pm
Im not looking for a fix , i fixed mine years ago, i wanted people to
watch this area if they have not all ready modified it,this about the
subject of loosing sleep over some area !
Dennis Finley
On 2/3/10, Ralph Baker <rebaker@sc.rr.com> wrote:
Dennis Finley
Dennis,
Wayne has mentioned his fix in the past. It should be archived. He
suggests using brake line to fashion a tubular spacer on either side of the
rod end ball. The spacer length is long enough to allow rotation for stop
to stop (fore & aft) plus a smidgen for clearance.The spacer wall thickness
has to be enough to withstand bolt compression and turning force but not so
thick as become an interference.
As another option -which I am using - ACS has a part that allows rotation
internally and is threaded in each end for the rod ends. No ACS catalog
here at home and it is a little obscure to find but solves the threaded
rotation.
