[rebel-builders] aileron push pull tube
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 6:02 pm
What bulkheads...the overhead ones or outside the cabin where the one longer
push-pull tube connects to the wing torque tube?
1" sounds right, though I'd have to go measure mine at the hangar to be
sure. I have a ton of space around my cabin push-pull tubes. I can't
imagine how your clearance is that close. The outside-cabin, longer,
push-pull tube clearance is tighter, but still plenty of space.
Post a couple of pictures to the site or email me some @ ted@vafm.org
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
R. Greaton
Sent: Monday, February 01, 2010 6:26 AM
To: rebel builbers list
Subject: [rebel-builders] aileron push pull tube
Is the 1inch tubing the right size for the aileron push pull tube? The
clearance is extremely tight and seems to rub on the bulkheads.
Dave Greaton
Moose 189
David R. Greaton
Post by David R. Greaton » Sun Feb 19, 2012 6:02 pm
Hi Ted,
It's is the ones that are in the wing attaching tie aileron to the torque
tube.
Dave Greaton
Sent: Monday, February 01, 2010 8:35 AM
Subject: RE: [rebel-builders] aileron push pull tube
longer
David
R. Greaton
Dave Greaton
Moose 189
Ted Waltman
Are they--the push pull tubes--parallel to the wing & cabin (good), or are
they running at angle (not good). Take a picture if possible, though I
suspect either your wing mount point is too long or your cabin one too short
(or both)--shouldn't happen, though, as I don't recall any need to trim the
wing one.
R. Greaton
Sent: Monday, February 01, 2010 7:03 AM
Subject: Re: [rebel-builders] aileron push pull tube
Hi Ted,
tube.
Dave Greaton
longer
David
R. Greaton
Dave Greaton
Moose 189
David R. Greaton
Hi Ted,
They are the tubes that are at the mid point in the wing near where the
strut attach is.
DG
Sent: Monday, February 01, 2010 9:20 AM
short
wing one.
David
R. Greaton
Hi Ted,
tube.
Dave Greaton
longer
David
R. Greaton
Dave Greaton
Moose 189
Ted Waltman
Oh, sorry. I misunderstood. Can you add washers to one side or the other
with a longer bolt to move the tube position so it doesn't rub?
R. Greaton
Sent: Monday, February 01, 2010 7:52 AM
Hi Ted,
strut attach is.
DG
short
wing one.
David
R. Greaton
Hi Ted,
tube.
Dave Greaton
longer
David
R. Greaton
Dave Greaton
Moose 189
David R. Greaton
Unfortunately no. the rivets are binding on the sides at the aileron end. I
can get adequate clearance at the torqur tube but not at the aileron.
What about using a smaller diameter tube. like raw stock 22 (3/4" vs 1")
would that be strong enough
Sent: Monday, February 01, 2010 9:57 AM
David
R. Greaton
Hi Ted,
strut attach is.
DG
are
short
wing one.
David
R. Greaton
Hi Ted,
tube.
Dave Greaton
longer
David
R. Greaton
Dave Greaton
Moose 189
Ted Waltman
[rebel-builders] Aileron Push Pull Tube
Dave,
If you used 4130 tube as per part # I emailed you likely would be Ok.
Better Heim/Aurora bearings help side-to-side motion.
Seems that you're doing everything else right from what I can tell.
Good job!
R. Greaton
Sent: Wednesday, February 03, 2010 6:05 PM
Subject: [rebel-builders] Aileron Push Pull Tube
Hi All,
Sorry I have been away.
Thanks Jeff I had thought about down sizing but agree. Not such a good Idea,
Ted you are right it's the tube in the wing and the rivets are rubbing on
both the aileron bulk head (the curved part that faces the wing, the rivets
are also rubbing on the wing spar. I have ground a few thousandths off the
spar and adjusted the side play on the aileron, clearance is ok have also
spread the aileron bulkheads apart a few thousanths and seem to be getting
clearance but just a few thousanths.
Next I think I need to shim the aileron bushings to prevent side to side
motion on the aileron. Thinking of using nylon spacers.
Any comments please advise.
DAve Greaton
Moose 189
