Just wanted to say thanks to Wayne! Dug this up form the archives... saved
me a ton of time and frustration.
Used the method described by Wayne to even out the spade tips, and bring
them in line with the horizontal stab. Worked like a champ!
Thanks, Wayne!
~Kory
678E
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> Wayne G. O'Shea
-> Sent: Wednesday, March 28, 2007 9:09 AM
-> Subject: Re: [rebel-builders] Elite Elevator Mods
-> Before you get too far into redoing the other tip...
-> When I inherited a Moose project the elevator spades had a good twist in
-> them. I found that by retaining one side at it's original #30 and twisting
-> the spade straight... that the holes on the other side were only misaligned
-> by the the amount necessary to drill them up to a 5/32 rivet. Drilled a
-> couple fresh holes to hold it straight and then brought the old holes up to
-> 5/32 and riveted... cured the twist.
-> Wayne
