[rebel-builders] pedal distance from firewall
Posted: Sun Feb 19, 2012 8:58 pm
Ben,
Just measured mine, the hole nearest the firewall is at 6.75". I have the
witches hat inside as well and with the left brake fully depressed it's a
little less than an inch from the hat. Move it now, don't see any gotch's,
unless your 7' tall.
Randy 320R
Sent: Wednesday, January 27, 2010 9:30 AM
Subject: [rebel-builders] pedal distance from firewall
Randy 320R
I'm wondering about preferred distance of the pedal tubes from the
firewall. I
drilled holes for the delrin mount blocks last night using the 5 3/4 "
setback
from firewall called for in the manual. Of course, I wished I was asking
this
before I started those holes! Using that 5 3/4" setback, it looks to me
like
the normal straight rudder position would have the pedals leaned back too
much to allow enough forward travel on the pilot side right brake pedal.
I had switched the firewall witches hats (inside one starts at pilot's
feet), so
the pilot's right brake pedal hits there pretty early. It seems that even
with
the normal witches hat configuration it might be too close too.
I think my cleanest fix is to move both left and right side pedal tubes
rearward by the distance of the hole spacing in the delrin blocks -- I
think
about 1 1/4" (i'm at work now, didn't measure last night). That way I'd
use
one of the two 3/16" mount holes, drill new ones for the rear of the
blocks,
and fill the unused front ones with 3/16 rivets up through the doublers.
Fortunately I haven't drilled for the doubler perimeter holes, so things
won't
be too ugly.
So, two questions: Have others found forward rudder or brake pedal travel
to be no problem at that standard position (5 3/4" setback)? Are there
any
other potential gotchas by my moving both pedal ass'ys rearward a little,
e.g.
1 1/4"?
Thanks a lot, as always,
-Ben/ 496R
