3 Blade Warp Drive on O320 - 150HP
Posted: Fri Feb 17, 2012 11:34 pm
In completing my annual & after attending the last builders meeting at
Brampton, I followed Jack Wiebe's advice and took a close look for
cracking of the blades even though I'm running the low compression O320.
On two of the blades there were cracks around the circumference or the
aluminum collar at or just outside of the hub but no cracks running up
the blades towards the tips. The outboard 1/4" clamping bolts have
always been torqued to 110 inch pounds and the propeller mounting bolts
to 29 ft.-lbs through a 1/4" crush plate. Anybody got any ideas?
The Flying Rebels List is for the discussion between
builders and owners of complete/flying Murphy Rebel
aircraft. Archives located at:
